Go to Post Please forgive any possible profound language. - PortugazD.Ace [more]
Go Back   Chief Delphi > Technical > IT / Communications
  #31   Spotlight this post!
Unread 27-06-2004, 14:02
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: Using Linux?
I'm 99.9% sure the ansewr is yes, but I'll ask anways. It's a very safe bet to backup your computer before doing any of this, correct?
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
  #32   Spotlight this post!
Unread 27-06-2004, 14:44
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: Using Linux?
Absolutely. Backup before installing Linux. And after. And very very often.
One more thing - make sure that you can recover from your backups as well - all my backups used to be to CDs, but I have recently discovered that I can't read my earliest CD-Rs any longer, namely ones from before 1999.
If you want to get started with Linux, I think that Red Hat Linux 9 or Fedora Core (either 1 or 2) are excellent choices. Everything is already set up for you. I found it quite easy to install Red Hat 7.2 (back when I first started) and immediately I had a development environment, excellent GUI, and office tools (KOffice).
Eventually, you will get annoyed with the fact that Red Hat/Fedora has customized everything just a little, enough to cause frustration to people who like to understand the complete workings of Linux. Right now, I'm very significantly confused by the graphical bootscreen of Fedora Core 2 (how the hell do they do that?).
But yes, backup and good luck!
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
  #33   Spotlight this post!
Unread 27-06-2004, 14:54
AKA: Eric Hansen
Re: Using Linux?
Is using the backup program that comes w/ Windows XP a good program? (Sorry for the newbie-ish questions here, but hey; why not). I'm going to test RedHat on a LiveCD, and see if I like it.
Y!: synsoflife
  #34   Spotlight this post!
Unread 27-06-2004, 15:19
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Re: Using Linux?
SuSE has that too. It's called a Bootsplash. Here's an outline of how it works (and how to change it):
http://www.bootsplash.org/
There's also more splash screens available on KDE Look (I believe it was somewhere within this category, but could be wrong)
http://www.kde-look.org/index.php?xsortmode=new&page=0
But that's a bit off topic, isn't it?
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
  #35   Spotlight this post!
Unread 27-06-2004, 15:40
FRC #0030
Re: Using Linux?
I have never used the Windows XP Backup tool, but I have heard that its not that good.
But, why even bother with a backup tool? Find all the files that you use, will use, and have ever used (eg all documents, pictures, music, thesises, codes, novels, etc.) and copy those onto your backup medium of choice. I use CD-Rs in the absence of something better.
And btw, is there such a thing as a Redhat livecd?
Team 30, 2002-2005
  #36   Spotlight this post!
Unread 27-06-2004, 16:12
Re: Using Linux?
There isn't one pre-packaged as an ISO distributed directly by Redhat or the Fedora Project. It is possible to make one, of course, and there's most likely either a Redhat-derivative which is distributed as a LiveCD, or an "unofficial" LiveCD somewhere.
Knoppix and DemoLinux are Debian based, SuSE LiveCD is SuSE based (of course) and that covers the ones I've seen around lately.
  #37   Spotlight this post!
Unread 27-06-2004, 16:21
AKA: Eric Hansen
Re: Using Linux?
I did it for all the registry info and stuff like that.
As for the LiveCD, I ment SuSE, not RedHat (sorry). The LCD of SuSE is availible here if you want to check it out by the way.
Y!: synsoflife
  #38   Spotlight this post!
Unread 04-07-2004, 13:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Using Linux?
Yes. Linux requires 2 new file systems (neither Win32 or NTFS). I use the Hard drive backup utility in Nero. It does a sector copy to CD-Rs. The advantage is that even the partition table and MBR is preserved. The down side is that you have to restore the whole thing and you don't have access to individual files. Good for backing windows up before installing Linux.
  #39   Spotlight this post!
Unread 04-07-2004, 14:25
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Using Linux?
Adios is at least one I'm aware of.
  #40   Spotlight this post!
Unread 04-07-2004, 17:35
Re: Using Linux?
Well, requires isn't exactly true. There is, for example, a version of Slackware called Zipslack that will run off of Windows FAT partitions. I'm sure there are other distributions with this capability. Other distributions can do the same, with more or less effort. However, yes, the regular installation procedure is to create a native Linux file system of some kind, and most installers create a swap partition (however, if you already have a Windows partition, it's possible to share the Windows swap file, rather than creating a new parition to do the same thing). One example of a free sector by sector copying tool is dd (if Nero is not available). dd is almost certainly contained on all of the Live CD distributions.
  #41   Spotlight this post!
Unread 04-07-2004, 22:05
FRC #0030
Re: Using Linux?
I have been using Linux (of many varieties) on FAT partitions. I do this because I don't care about security and FAT is universally accessible. There are a few caveats about doing this though.
First, you can't have symlinks. A direct consequence of this is that you cannot compile a linux kernel (as far as I know) on a FAT filesystem, as one step in the compile involves the creation of a symlink. Second, you lose all security. Any user can access any part of the filesystem. A non-root user can still do pretty much anything on a FAT system. Third, you lose many of the features of chown (change ownership), chmod (change mode), and ACLs.
Even then, for my uses, the benefits of universal access of any OS to any OS far outweigh the problems. I wouldn't recommend doing this unless you are sure of what you are doing, but if you are sure of what you are doing, then there are better options. Until that Linux NTFS driver gets better.
Team 30, 2002-2005
  #42   Spotlight this post!
Unread 05-07-2004, 16:53
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Re: Using Linux?
Actually, ReiserFS, ext2, and ext3 can all be read by Windows. Not natively, of course.. but with some work, you can get it to work.
Most notably:
Explore2fs: http://uranus.it.swin.edu.au/~jn/linux/explore2fs.htm (r/w: ext2, ro: ext3)
rfstool: http://p-nand-q.com/download/rfstool.html (read-only and ignore journaling)
There might be some for jfs/xfs/etc.. but I don't feel like finding them E2fs works well, rfstool is.. decent.. but it does work.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux: steps to program fullsize RC robot rwaliany Programming 31 14-02-2004 14:45
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
