Go to Post Does this mean it's too late to ask for a flux capacitor? - Peter Matteson [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations
View Poll Results: Which control Method is best?
"Analog Mouse" 7 43.75%
"Mouse Follower" 1 6.25%
"Voodoo Mouse" 7 43.75%
Other 1 6.25%
Voters: 16. You may not vote on this poll
Unread 06-07-2004, 18:06
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
[FVG]: Controls Round B1
we've officially decided that a combination of mouse and keyboard play would be best for the game, now we need to decide what kind of controls we will have. here is the first round of options and their features:
  • "Analog Mouse"
    • mouse is aimed in circle on screen to determind speed and direction
    • keys are used to perform robot actions
  • "Mouse Follower"
    • robot aims itself in direction of mouse pointer on floor.
    • robot actions are performed by clicking on the object, robot will automatically perform the corresponding action
    • pausing, and choosing between multiple mouse actions from a menu in some circumstances would be doen through the keyboard
  • "Voodoo Mouse"
    • drive of robot is operated through keyboard
    • a second model of the robot is located in a box in one corner of the screen, which always corresponds with the one on the field.
      • players can click on servo-type mechanisms on this model to move them on the field model
      • players can click and drag arms and other parts of the bot that have many different possible positions.
      • players can rotate the model to reach all mechanisms
Unread 06-07-2004, 21:03
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: [FVG]: Controls Round B1
Nooo, no, no, no.
Configurable.
on the OI, you have 16 analog inputs and 16 digital inputs. An combination of mouse, keyboard, or joystick axis/buttons can be accepted to control this.
And the mouse can be "Position" based (To the left side: x = 0) or "movement" based (keep going left tp keep x = 0).
As for keys, it's simple. Left means X=30, Right means X=225.
Analog to digital is similar. Have a threshold. (X<30 means left, X>225 means right)
Anything else?
Unread 06-07-2004, 21:22
Originally Posted by Astronouth7303
Nooo, no, no, no.
Configurable.
Anything else?
i have no idea what you're talking about... i guess we can include this in round B2, but you should explain it more first
Unread 06-07-2004, 21:35
Nastay's Avatar
Nastay Nastay is offline
Jim Smith
AKA: Jim Smith
#0236 (Techno Ticks)
Nastay is an unknown quantity at this point
Send a message via AIM to Nastay
the point and click mode and have the robot follow and do stuff automatically doesn't seem like a good idea... why not just have the keyboard do it all.... sure the analog things would end up being digital things because the keyboard is on or off (1 or 0, digital). but i was actually picturing this from a First Person POV from the drivers box. And the user could program what ever buttons to do what ever they wanted, and if they had a joystick (or two) they could use that, so it would be like you are actually controlling that bot, instead of just kind of moving it around and having stuff get done automatically, thats not what FIRST is like at all.
By the way, i am starting the programming course tomorrow (the 7th) i think it goes for most of the summer... but i have no idea what language we are learning (it will obviously be c or a varient, whether its C, C++ or obj-C i have no idea, i hope C++ or obj-C)
First Video Game! - Port Leader
sudo rm -r -f -v /
Nastay
21
Unread 06-07-2004, 21:40
i thought of that too, and i agree. thats y i changed my vote to the voodoo method. i think that will be the most efficient, easiest, and most vercitile method of control,
Unread 06-07-2004, 21:47
Nastay's Avatar
Jim Smith
AKA: Jim Smith
ok ok, what exactly is voodoo mode? do all of the controls on the keyboard with the voodo corner thingy as an extra or is that the primary way to activate the controls? i think putting everything on the keyboard would be most realistic, but the voodoo thing sounds cool too....
sudo rm -r -f -v /
Nastay
21
Unread 06-07-2004, 22:01
AKA: Jamie Bliss
ok.
There is a config dialog. You can map each input to an OI pin.
The inputs are:
  1. Mouse X, Y, H, V (scroll wheel)
  2. Mouse buttons (1-5)
  3. Keyboard buttons (include alt, ctrl, shift, win?)
  4. Joystick axis 1-6
  5. Joystick buttons 1-32
  6. possibly dashboard/RC
1, 4, 6 are analog; 2, 3, 5, 6 are digital
Mouse XY can be based on position or rate of movement.
the conversion between analog/digital is actually pretty simple. It's based on a value.
  • in A>D, the value is a threshold. below = unpressed, above = pressed. also can make an axis do 2 buttons, one above center, one below.
  • in D>A, the value is a number. (eg if Key=pressed then axis=number)
so how this all works together is that the sources map to OI inputs (16 axis, 16 buttons). These values are fed to the robot. presto! controls done.
As for connecting to the OI/RC, I have 2 ideas:
  • use the dashboard port and set it to send OI data
  • connect to the prog port on the RC and have it send the values. (in a 20 byte packet). I could write a program to do that, I think.
obviously, the OI setup would map directly to the inputs.
suddenly, every one of our computers have 4 more wireless gameports.
Unread 06-07-2004, 22:09
Coco the Monkey's Avatar
Coco the Monkey Coco the Monkey is offline
Anyone up for some Hot Coco?
AKA: Vince Moore, or Coco
FRC #0768 (The TechnoWarriors)
Coco the Monkey will become famous soon enoughCoco the Monkey will become famous soon enough
Send a message via AIM to Coco the Monkey Send a message via MSN to Coco the Monkey Send a message via Yahoo to Coco the Monkey
I agree that Voodoo would be the best option. If this is the option we decide to go with, I suggest that we consider a few things:
1) Some sort of function recognition for the player to know what part they are selecting, (i.e. The parts glowing and a name appearing when the mouse is hovering over it, etc.)
2) Rotating the Object would take game time to do, you could just have flags satellite off the model, with the different functions written in them for faster access
3) Possibly combine the Voodoo and the Follower models, have robot actions by clicking on the object and the robot does it to the best of its ability. I like that aspect of the Follower mode.
4) Maybe have Both modes and allow players to choose the type they like?
2007-Present: Mentor of team 768 The Technowarriors
2001-Present: Member/Alumni of team 365 The Miracle Workerz GO MOE!
I'm seeing a pattern in the teams I've been a part of... Gotta love the green
AIM: ArtXCoco
Unread 06-07-2004, 22:20
AKA: Jamie Bliss
Don't forget that we need compatibility with other years. (Maybe even '92! )
Anything that complex means a massive overhaul of the current interfaces (which isn't saying much).
Unread 06-07-2004, 22:38
for the voodoo mode, we would have small red circles on the robot called "handles" you just grab onto that handle and drag it.
let's use MOE's arm for an example:
say MOE's arm is at a 90 degree angle. the player would grab the handle and move the pointer over. now we know that nobody can keep the mouse on the exact edge or the circle of rotation, so here's essentially how it would work. when the pointer is moved, the computer draws a line from the joint to the pointer location. then it rotates the arm until the handle hits the line. basically matching the angle. well, this may not be exactly how it would be programmed, but essentially how it would respond.
now, let's consider a 2-jointed arm, like my team had:
we would have a system like this for each joint, but for operating ease, we can have a special key to activate an alternate mode when held. the player would hold this key down, and grab the handle at the end of the arm. now, anywhere within the arm's range, that point would go, and here's how. the computer would form a triangle between the two arm segments and the line between the handle and the first joint. this way, it would be like actually grabbing the arm at the end (like we can on our controls) and pulling the middle joint in space, allowing the two to turn to the point where they fit.
these handles would act almost like the title bars on windows, click and drag.
Unread 06-07-2004, 22:44
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Sounds nice, but I think it's a bit complex for gameplay. I think it would be easier to have something like W=first stage up, S=first stage down, E=second stage up, D=second stage down (not necessarily those keys)
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 06-07-2004, 22:57
we use the same exact principal on our robot's arm. it sounds complex, but when you use it (which i have) it is really easy. and fun . ask teknobrahma, he's the arm operator... and he voted for voodoo.
Unread 07-07-2004, 05:54
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I agree with HHSJosh. I think that the voodoo things may be too complicated to be handled well. I think that instead of making the user do most/all of the work by mouse, we should do something like:
  • Robot movement - Done by the "analog circle" idea
  • EX of an arm which has to joints and a winch/hook combination:
    • You hold down 'a' to activate the lower joint. That joint is now movable by the mouse in the analog circle. (I.E. the farther from center, the quicker the movement. The side of center in the circle would determine which direction. Position off of the vertical/horizontal diameter (depending on joint orientation) would be ignored as joints can't move in more than 1D (mostly. good enough for our purposes)) To deactivate the joint and allow robot control again, just release the key.
    • Same thing for the upper joint, only with, say, the 'q' key.
    • For the winch, very similar idea. To activate, hold done a key. The mouse then contols its speed/direction. (and, yes, we would limit it in one direct because it is a winch. Maybe we could 'break' it if it goes the wrong way...)
So... I'm done...
P.S. Oh, wow, that was scary. After I finished typing that, I posted it... and the site was down for backup. Lucky for me Firefox saved everything...
Unread 07-07-2004, 09:28
actually, i was thinking about this, and i think now that the best way would be to have the voodoo method, but also have keyboard override.
Unread 07-07-2004, 11:47
Joshua May's Avatar
Go Bears!
So... I'm done...
How about you activate the arm with the 'a' key, but then use the up and down arrows to actually move the arm.
Really with the voodoo and that, even with moving the mouse to move objects with a keyboard select, that takes away from the movement of the robot for a second, doesn't it? It would be better if players could multitask and move the robot while performing a specific function, IMHO. It doesn't sound right if the driver has to stop, put the arm up, and move again, you lose valuable time.
[FVG]: Controls Round 2 Mike Ciance FIRST-related Organizations 2 05-07-2004 16:21
[FVG]: Controls Round 1 Mike Ciance FIRST-related Organizations 10 05-07-2004 16:00
[FVG]: Human Players Round 2 Mike Ciance FIRST-related Organizations 8 04-07-2004 14:03
[FVG]: Human Players Round 3 Mike Ciance FIRST-related Organizations 6 29-06-2004 05:52
[FVG]: Name Round 2 Astronouth7303 FIRST-related Organizations 6 21-06-2004 21:40
