Go to Post I once started to build a time machine. But then I went back in time and told myself that it wouldn't work, so I gave up on it. -dave - dlavery [more]
Unread 07-07-2004, 05:29
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
frying control board
Just a quick question.
Our robot is made out of inch square angle , and i need to do a bit of welding on the lifter (its from the box lifter one)
what i want to know is, if i do some MiG welding on the robot lifting arm (the vertical bits) will it blow up the control board? It is bleeding hard to get the control board out as i will have to remove EVERYTHING else....
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 07-07-2004, 06:56
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: frying control board
Probably not. As long as you aren't near the bottom, it should be fine. The lexan/whatever covering should keep it plenty safe.
But, I don't endorse my own answer, so if anything happens...
Unread 07-07-2004, 07:21
Denman's Avatar
AKA: Stephen Denman
oki doki, the mentor i found just said the same, so i suppose it should be ok
but if it blows up, i will be back and warning you not to do it yourself lol
Unread 07-07-2004, 08:00
Den,
This is one of those situations where you need to weigh the benefits against the hazards. For a few minutes of frustration you save the $1000+ price tag of a new controller. Seems like a no-brainer to me. There should not be any direct connection between the frame and the electronics but the welding process passes huge amounts of current through the frame. Current passing through a conductor induces a magnetic field (Huge currents=huge fields) and conductors in a magnetic field induce current flow.
Unread 07-07-2004, 08:02
Denman's Avatar
AKA: Stephen Denman
its going to take me several hours, not a few minutes lol, and i would hten have to wire it all back up and mess around when it doesn't work... it has to be done by friday as well..
what about if i stick the earth in a place where the current will go straigt away from the rc?
ie if i am welding half way down it, if i earth it at the top??
Unread 07-07-2004, 08:35
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Not only will you have the risk of frying the controller, but also the spikes and victors you have the chance of zapping and destroying. If it is going to take a few hours to remove the RC and other electronic, then you might have one other option. Can you remove what you need to weld and weld that off of the robot and place it back on when you are done. I would not suggest MIG welding a robot that has its electronics still attached.
-Michael Dessingue
Unread 07-07-2004, 08:40
Denman's Avatar
AKA: Stephen Denman
hmmmmm that might be possible actually... i will go and see now...... thanx
Unread 07-07-2004, 19:11
Racer26 Racer26 is offline
Well, I know for a fact that as long as your ground clip stays ON the robot you will be fine, the problem is, that the clip falls off relatively easily, and then it may touch some electronics... 1075 lost a whole robot's worth of Victor 884's (6) and the multiplier chip in the RC, requiring us to get a new one. But, since our sponsor was welding it, we didn't have to foot the bill. Also, if your 'bot is aluminum, I wouldn't recommend MIG welding. All of 1075's welding is TIG... but that's my 2 cents. (I'm not a welder so I don't know if its even possible to MIG weld Aluminum)
pic: Team 294 Control Board: View 2 CD47-Bot Extra Discussion 17 11-08-2004 17:21
Designs for control board? batbotcrewfrosh General Forum 6 05-02-2004 00:00
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
