Go to Post Be the change you want to see. - staplemonx [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations
Unread 07-07-2004, 15:47
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
[FVG]: OI or RC as control input
Several times I have proposed using the OI/RC as the control input. Here's my write up on it.
There are 2 ways to do this: use the dashboard port or write a program for the RC.
  • Dashboard
    Use the OI (with or w/o RC) as 4 game ports. you hook up the original controls & the dashboard and you're all set!
    PROS:
    • Lots of game ports.
    • original controls work
    CONS:
    • May not work w/o RC
    • Not everyone has an OI
    • Not everyone has an RS-232 port
  • RC
    You load a program to the RC and hook up the prog port to your PC. You turn it on and it should work fine!
    PROS:
    • Wireless!
    • almost garenteed to work
    • Can be made to work with previous years
    CONS:
    • May require the big batt (see below)
    • Not everyone has an OI/RC
POWER
There are a couple of things we could do for power of the RC/OI:
  • Use the original equipment (safest, heaviest?)
  • Make an AC adaptor for the RC (most cords)
  • Make custom battery backs (need to replace batteries)
I guess that is more of an user problem, not our problem.
I've attached a version of the code for the RC. (79.5 KB)
Unread 07-07-2004, 19:42
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
Re: [FVG]: OI or RC as control input
we could include this as a deluxe feature, but we obviously need to have a keyboard/mouse configuration also.
Unread 07-07-2004, 20:17
AKA: Jamie Bliss
In addition. I'm advocating complete config.
Unread 08-07-2004, 05:56
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ok, ok, we'll do it for you...
But, you get to be in charge of that...
[FVG]: Controls Round 1 Mike Ciance FIRST-related Organizations 10 05-07-2004 16:00
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
goals: how much control? Pat Sarmiento Rules/Strategy 2 18-01-2002 19:10
