Go to Post Change your process to change your product. - Justin Montois [more]
Unread 10-07-2004, 01:23
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Cheap bipedal robot
This is just amazing. A small, programmable, bipedal robot for (only) $1400. I love the simple construction, just bolt an arm directly to a servo horn. So good. The software must be so simple, too, because the servos handle getting correct position themselves. Imagine what other amazing mechanical articulated stuff one could do with this simple servo construction. If I can possibly find an excuse for a small, 3+jointed arm with low torque and speed on next year's robot, I will have to use this kinda stuff. Maybe I should make a robotic hand to shift the drill gearbox, seems like no mechanical device can do it as well as a hand
Team 1257
Unread 11-07-2004, 01:18
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: Cheap bipedal robot
absolutely incredible. I want one. Did you see its Chop-Socky there at the end of the vid?
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 11-07-2004, 01:31
Fold em oval!
I assume you mean that sweet kung-fu routine type thing. That is just amazing. I love they way they make the leg servos oscillate slightly while its holding a position to give i that realistic heaving motion. I'm surprised it has no grippers. Guess that will have to be my first mod
Team 1257
Unread 11-07-2004, 01:44
#1067 (SLUH)
Good luck finding actuators small enough. You would have to use motors from slot cars or something, you won't find a servo that small (without paying top dollar).
Are you really buying one? Tell me how it turns out if you do, because if it is as cool as that video makes it look like (did you see how fast it is capable of moving?!?!?!?!), I might have to get a second job . . . . .
Unread 11-07-2004, 13:07
Fold em oval!
No, I wouldn't buy one, but it's the simplicty of the construction that amazes me. I would try to build one myself first. It looks like you could practically build it without anything more than a hand drill and some sheet metal snips. The speed seems amazing, but that's just how fast servos move with a low load like that. Just try some of the kit of parts servos, they are about that fast.
Team 1257
Unread 11-07-2004, 16:16
#1067 (SLUH)
Yeah, but it has something like 17 servos. Good luck finding a tiny controller that can deal with that easily. Well, actually, they probably exist and I doubt that they would be ridiculously expensive. And then you could add some rotational accelerometers for balance, and all sorts of fun stuff.
Unread 11-07-2004, 16:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Would this be small and cheap enough?
[moderated] Brainstorm: Aggressive play rule Aidan F. Browne General Forum 11 26-04-2004 20:29
Building more than one robot / expanding the "season" Mr. Van General Forum 25 19-02-2004 17:51
Righting a robot... archiver 2001 2 24-06-2002 00:26
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
