Re: Dewalt Transmissions
See Dewalt Products Here
Order Dewalt Service Parts Here I recommend anything with the XPR transmissions (but the Hammer Drill versions are not value added so avoid them) Specifically: DC980KA (12V version) DC983KA (14.4V version) DC987KA (18V version) The parts you need are at the link for service parts above. I have set up a sham account: login: "chiefdelphi" pswd: "team47" Go to "saved orders" look under "FIRST ORDER" It totals a bit over $100 for the lot (including a motor). Mike Martus is working hard on the whitepaper. I am pedalling as fast as I can. We will get things up as soon as we can. This is a link to a PDF file showing an exploded view of the DC980KA drill and the associated part numbers. Joe J. |
Thanks Dr. Joe,
Got the Parts List from the Dewalt web site. I guess Part 608060-00 Detent Shifter is not needed as it was not included with your list of parts? Joe P |
Joe,
How much torque do you think one gearbox can handle? Enough to pair two motors together to one input shaft to the gearbox? i.e. the Chip and the drill motor? My hunch says I'm probably pushing it... |
DeWalt uses the same tranny for the 12, 14, and 18v drills, with the 18 producing 450 in-lb of torque. Unlike the Bosch, which uses plastic for the ring gears, the DeWalts are all metal. So, my "guess" is that they can take it - we'll find out. |
#7
| Off the shelf transmissions | CharlieWilken | Technical Discussion | 0 | 15-01-2004 01:58 |
| Drill transmissions | camtunkpa | Technical Discussion | 3 | 12-05-2003 21:21 |
| A little tip about those drill transmissions and bearings | archiver | 2001 | 6 | 24-06-2002 00:22 |
| what teams have a variable transmissions? | Greg Perkins | Technical Discussion | 4 | 06-03-2002 06:10 |
| drill motor transmissions | nwagers | Motors | 16 | 29-01-2002 10:54 |
