Go to Post When there appears to be something stupid wrong with a game (HPs outscoring robots, unreliable loading, autonomous that accomplishes nothing) I shouldn't complain about it. I should see it as a challenge to exploit! - Chris is me [more]
Unread 12-07-2004, 17:04
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: 10 gauge wire getting way hot
Originally Posted by dmellich
Ok, here's a problem for you electrical types.
We recently experienced a near meltdown on the 12 gauge ground wire that comes out of the "distribution block" (new this past season) and feeds into the speed controller. The meltdown was actually the plastic that acts as a case for the metal connections in the block.
There were no problems prior to this incident. Any thoughts?
ps When I say meltdown, I mean the wires got hot enough to soften the plastic
Could you provide some more information?
What was the wire connected to? Were their problems with that component?
Generaly, hot electrical components suggests a high resistence connection. My first guess is that over time vibrations loosened the screw that holds the wires in the block, and the poor connection caused excess heat. Since it sounds like the heat was highest right around the screw terminal, it's a likely culprit.
In any case check that distro block carefully- the heat may have really screwed with it, and it may no longer be safe to use.
-Andy A.
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Line sensor wire gauge questions Dinush Electrical 6 13-02-2004 18:41
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Motor wire sizes Tim Skloss Motors 5 13-02-2002 07:44
