Go to Post Note that these comments are based on the 2006 FRC game rules, and they may or may not apply to the 2007 game. Your mileage may vary. - dlavery [more]
Unread 12-07-2004, 22:16
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Dewalt Transmissions
See Dewalt Products Here
Order Dewalt Service Parts Here
I recommend anything with the XPR transmissions (but the Hammer Drill versions are not value added so avoid them) Specifically:
DC980KA (12V version)
DC983KA (14.4V version)
DC987KA (18V version)
The parts you need are at the link for service parts above.
I have set up a sham account: login: "chiefdelphi" pswd: "team47"
Go to "saved orders" look under "FIRST ORDER" It totals a bit over $100 for the lot (including a motor).
Mike Martus is working hard on the whitepaper. I am pedalling as fast as I can.
We will get things up as soon as we can.
This is a link to a PDF file showing an exploded view of the DC980KA drill and the associated part numbers.
Joe J.
Unread 13-07-2004, 10:29
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Thanks Dr. Joe,
Got the Parts List from the Dewalt web site.
I guess Part 608060-00 Detent Shifter is not needed as it was not included with your list of parts?
Joe P
Unread 13-07-2004, 15:50
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Joe P
Thanks Dr. Joe,
Joe P
The detent comes with the transmission. JJ
Unread 30-07-2004, 17:08
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
Joe,
How much torque do you think one gearbox can handle? Enough to pair two motors together to one input shaft to the gearbox? i.e. the Chip and the drill motor?
My hunch says I'm probably pushing it...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 31-07-2004, 00:18
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Originally Posted by 2000vfr800
Joe,
That's a good question. Last year our team used 1/motor/drive_wheel = 4, which meant shifting 4 at a time. Next year, we plan to pair them as you mention.
DeWalt uses the same tranny for the 12, 14, and 18v drills, with the 18 producing 450 in-lb of torque. Unlike the Bosch, which uses plastic for the ring gears, the DeWalts are all metal. So, my "guess" is that they can take it - we'll find out.
Unread 09-09-2004, 21:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by Jack Jones
- we'll find out.
Not necessarily. No one confirmed (or even heard really) that we are actually getting these.
Off the shelf transmissions CharlieWilken Technical Discussion 0 15-01-2004 01:58
Drill transmissions camtunkpa Technical Discussion 3 12-05-2003 21:21
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
what teams have a variable transmissions? Greg Perkins Technical Discussion 4 06-03-2002 06:10
drill motor transmissions nwagers Motors 16 29-01-2002 10:54
