Go to Post resist the hive: As goofy as this may sound, wires do take up weight, several pounds of it. - Rickertsen2 [more]
Unread 12-07-2004, 22:27
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Exclamation Re: 10 gauge wire getting way hot
Originally Posted by Andy A.
Generaly, hot electrical components suggests a high resistence connection. My first guess is that over time vibrations loosened the screw that holds the wires in the block, and the poor connection caused excess heat. Since it sounds like the heat was highest right around the screw terminal, it's a likely culprit.
I disagree...hot electrical components often sugesst a very LOW resistance connection. A shorted connection where there is very little resistance can cause more current to flow than the wires can handle. Resistors and resistance in general turn electricity into heat, but they reduce current flow at the same time.
I do, however, agree that more information is needed to diagnose the problem. Was everything functioning properly before the "meltdown"? Is the frame grounded?
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Line sensor wire gauge questions Dinush Electrical 6 13-02-2004 18:41
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Motor wire sizes Tim Skloss Motors 5 13-02-2002 07:44
