Go to Post rebound rumble didn't really have a lot of rebounding or surprise earthquakes. - Rynocorn [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 13-07-2004, 11:54
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Partitioning
What program(s) (if any) do you suggest on partitioning a hard drive? If you don't suggest any programs, and references on howto do it otherwise?
** Note: I'm going to be partitioning a Windows 98 system to hopefully install Linux (or a variant) **
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 13-07-2004, 11:56
Bharat Nain's Avatar
Re: Partitioning
If you use Mandrake Linux, while installing it gives you a option to partition the hard drive, provided Windows is installed first. I have used it and its very efficient.
Other than that, I have never partitioned my drive, so I have no programs to offer.
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 13-07-2004, 12:02
AKA: Eric Hansen
Re: Partitioning
-Bharat
Thanks very much. I'll probably try to install Mandrake Linux, since it also seems to be a popular choice outside of RedHat.
Y!: synsoflife
Unread 13-07-2004, 12:27
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Partitioning
You don't even need to install it to partition. All you have to do is put the first CD in, get through some stuff about your keyboard and mouse, then you can do that. After you finish the partitioning and hit "Next" (or whatever it says) and it finishes the partition changes, you can Ctrl-Alt-Delete to restart you computer.
Unread 13-07-2004, 12:30
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
Re: Partitioning
For general partitioning, also for modifying partitions, deleting, or merging them, I use PartitionMagic: http://www.powerquest.com/partitionmagic/
Its great.
pi is exactly 3
IM me at: zmstr265
Unread 13-07-2004, 13:47
Rafi A Rafi A is offline
AKA: Rafghan
FRC #0935 (RaileRobotics)
Rafi A is on a distinguished road
Send a message via AIM to Rafi A Send a message via MSN to Rafi A Send a message via Yahoo to Rafi A
Re: Partitioning
partition magic is awesome. Also, Mandrake is not the only linux distro that parititions, i believe Suse (forgot capitilization) does too
Unread 13-07-2004, 14:36
AKA: Eric Hansen
Re: Partitioning
I was thinking about that, I might use it.
This is a lil' off topic, but it's SUSE now (yes, all caps...dunno why but it is).
Y!: synsoflife
Unread 13-07-2004, 20:46
Re: Partitioning
Are you going to be destructively or nondestructively partitioning
your hard drive? By destructive, I mean starting from scratch.
Nondestructive means keeping your existing data intact and shrinking
the existing partition(s).
If destructive is ok, then just use the partitioning program included
in the installation of the distribution you choose.
If you want to do it nondestructively, by far the easiest and safest
program is Partition Magic. However, it will set you back about $70
(although it is worth it, in my opinion, if you want to do anything
more then the bare minimum).
http://www.ranish.com/part/ is a good free program that can be run
from DOS. I've never had it screw up, but it has a steep learning
curve.
QTParted is included with knoppix. It has a gui and so is slightly
more intuitive the ranish partition manager, but just doesn't "seem
right" to me. In other words, I feel more comfortable with ranish,
even if it took longer to learn.
I think Mandrake may be able to nondestructivelty partition also, but
I'm not sure.
The main reason to use partition magic is it can handle many more cases
then either of the free ones. Often times, Windows 2000 and XP will
put files toward the end of your parition, and not move them when you
defrag. (I've run into this on more then one computer). ranish and
QTparted being merely partitioning programs won't move data, and so
can only shrink as far as the last data in the partition. Partition
Magic is much smarter and will move that data, and allow you to shrink
as much as possible.
My advice is to leave the free space unpartitioned, and then use the
partitioning tool included with your distribution to partition the
free space.
PS All major distros (and almost all others) include partitioning tools. Very few include nondestructive partitioning tools, though.
Unread 13-07-2004, 20:52
AKA: Eric Hansen
Re: Partitioning
I'm doing it non. I'll try out PartitionMagic, and see if it works for me.
It'll probably take a while though before I do this since I just realized today really that the computer only has a 12-gig hard drive (yes, it is very old), and is running Win98 SE.
Y!: synsoflife
Unread 13-07-2004, 20:53
Re: Partitioning
A
I'm not sure.
Thanks for reminding me, Mandrake can nondestrutively do it, but you have to defragment your disk PROPERLY before installing mandrake, otherwise it will eat up a part of windows.
-= Bharat Nain =-
Unread 14-07-2004, 11:25
AKA: Eric Hansen
Re: Partitioning
I have now got SUSE Linux 9.1 Personal dual booting on my old computer
Thanks to everyone for helping me
Y!: synsoflife
Unread 14-07-2004, 11:28
Re: Partitioning
Congractulations buddy
-= Bharat Nain =-
Unread 14-07-2004, 14:15
AKA: Eric Hansen
Re: Partitioning
I'd like to say though that SUSE doesn't have partitioning ability (unless it didn't show it for me since I already did partition).
Y!: synsoflife
Unread 14-07-2004, 15:26
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: Partitioning
I use Partition Magic 8.0 and I find it is excellent. Through a combination of deals at CompUSA, I managed to get it for 9 cents. =)
Apart from Partition Magic, I use the partitioning program built into the RedHat and Fedora Core installers (Disk Druid, i think). It is quite good also.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 14-07-2004, 20:18
Re: Partitioning
I haven't installed SUSE sinse version 8.1, but I'm sure they have a
partitioning tool. They may have just hidden it if you didn't choose a
custom install.
To qualify or not to qualify archiver 2000 10 23-06-2002 23:12
