Go to Post We have a lot of rookies, and I can't wait to see the inspiration on their faces. - Karibou [more]
Unread 12-07-2004, 22:01
cvhsrobotics's Avatar
cvhsrobotics cvhsrobotics is offline
AKA: Ara K.
None #0589 (Falcon)
Team Role: Student
cvhsrobotics is an unknown quantity at this point
Send a message via AIM to cvhsrobotics
Darn Teflon
This year I was the only team member that setup the Pnuematics, I just still have not gotten the trick of teflon, It grids of when you screw it in and that caused us a piston that got jammed.
Tips?
TEAM 589~!
Crescenta Valley High School Robotics!
Unread 12-07-2004, 22:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Darn Teflon
Hrrmm. Never had that happen. Are you wrapping it in the correct direction?
Unread 12-07-2004, 22:42
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
Re: Darn Teflon
Try and try again; had to try a couple times every now and again when the teflon wouldn't screw in right.
Joules per second! Watt? Joules per second! Watt? Jouls per second! Watt?
Unread 12-07-2004, 22:50
occra 23.
AKA: ryo
None #1481
Re: Darn Teflon
are you layering the teflon too much? that or you're wrapping in the wrong direction. i think... i used to have that problem, and i just ignored it...luckly it didnt jam anything, and eventually i think learned how to do it now.
Unread 12-07-2004, 23:32
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Darn Teflon
Tips?
Generally you don't need more than two or three wraps of teflon tape to get a good seal. If you do then the threads are bad and you need to junk the fitting. DO NOT wrap all the way to the end of the threads. Leave a little gap uncovered and you will prevent pieces getting lose and jamming things up
Christopher H Husmann, PE
"Who is John Galt?"
Unread 13-07-2004, 00:03
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Darn Teflon
I would suggest you taking a look in the FIRST Pneumatics Manual for in it the proper use if the teflon tape on the parts is shown, it shows you about how much to put on and where not to put the tape. I know that has helped out many people this past year.
-Michael Dessingue
Unread 13-07-2004, 00:12
RudimentaryPeni's Avatar
RudimentaryPeni RudimentaryPeni is offline
Registered Abuser
AKA: "Garth"
#1110 (Binary Bulldogs)
RudimentaryPeni is a jewel in the roughRudimentaryPeni is a jewel in the roughRudimentaryPeni is a jewel in the rough
Send a message via AIM to RudimentaryPeni
Re: Darn Teflon
There is a like paste stuff that you can put on it too, i dont know what it is called or if its legal or not but all i know is i have seen it used for fixing older pipe. You may want to check out the local Home Depot or Lowe's and ask them about it! (thought i would throw in an ad)
Matt Blake is no more politics!
Yes, That IS me on the robot, on my teams site!
The Coolest Guy On Myspace
Unread 13-07-2004, 01:45
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Darn Teflon
You might find it called "pipe dope" or "pipe thread sealant" or some such thing. Depending on the type of fitting, and on how often it is removed and replaced, that may be a viable option. It goes on messy, and doesn't really dry (like a glue would), but forms a airtight seal between the threads. As always, apply it sparingly, and don't let any get inside of the fitting (just on the thread surface).
Note that neither pipe dope nor teflon tape are appropriate for some high pressure fluid lines (like hydraulics)--that shouldn't be a problem for FIRST, but in the "real world" you may encounter dry compression threads (e.g. tapered plugs on hydraulic systems).
Unread 13-07-2004, 18:46
AKA: Ara K.
None #0589 (Falcon)
Team Role: Student
Re: Darn Teflon
I see I put teflon on the first ring or the screw and the First Pneumatics Manual said not to
TEAM 589~!
Unread 13-07-2004, 19:16
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: Darn Teflon
I also would like to add that Loctite makes a thread sealant also. It's more liquid (not as thick) as the typical brush on gray pipe sealant you get at hardware/home improvement stores. For the small 1/8" or so threads we use on the pnuematics in our kit it would be a better option. It is also removable (not permanent) so if you need to replace fittings or cylinders all is not lost. The gray stuff will work but it's more designed for larger fittings like the pipes in your house.
I also want to say it should be one or the other. You should never us pipe sealant and teflon on the same joint.
And a little hint. For most threads (right hand) if you hold the fitting with the threads facing you and wrap the teflon tape clockwise you will wrap it in the correct direction and not have to worry about the tape "bunchin up" or trying to unwrap when you install the fitting.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 13-07-2004, 23:09
Umm Errr...
Re: Darn Teflon
If you find teflon difficult then use loctite 545 or a similar product. We use it at work and its much easier.
1139 Alumni
Unread 13-07-2004, 23:51
AKA: Ara K.
None #0589 (Falcon)
Team Role: Student
Re: Darn Teflon
never heard of it but thanks
TEAM 589~!
Unread 16-07-2004, 00:04
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: Darn Teflon
When I normally do pnuematics dealing with teflon i usually only wrap the teflon once to twice around and make sure i really rub it in so the threads are outlined in teflon...if you use to much it bungs the threads and it will rip/tear or wont stay on.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 16-07-2004, 13:17
AKA: Ara K.
None #0589 (Falcon)
Team Role: Student
Re: Darn Teflon
hmm, good tip to rub it in so it doesnt shread
TEAM 589~!
Unread 16-07-2004, 13:52
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
Re: Darn Teflon
After making thousands of fittings up in my 25 years here are some tips.
Don't use tape on pneumatics - eventually you will have pieces that find thier way to plug up a valve. We Never use tape on our process air for that reason. Can you imagine shutting down a huge chemical process plant becase of a piece of tape debris, it happens. There are a lot of good thread sealants you can use. Contrary to popular belief in this area less is better. Again you don't want your thread sealant in your process. Don't over tighten - Brass seals fairly easily. Cross threading - every year we get a least one fitting that is cross threaded and then someone tries to keep it from leaking by using more tape or over tightening, throw away the fitting and get a new one. Remember tape is not the only debris - keep your pneumatics clean.
Have a great weekend
Ken
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
NCAA Championship David Kelly Chit-Chat 6 02-04-2002 23:12
Density of teflon and delron Jan Olligs Technical Discussion 2 26-01-2002 19:56
Gm Patrick Canale Championship Event 87 25-06-2001 11:13
