Go to Post 71% efficiency is best efficiency. ;) - Chris is me [more]
  #32   Spotlight this post!
Unread 16-07-2004, 12:04
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Re: Yellow card / Red card usage at 2004 IRI
Originally Posted by Collin Fultz
it's not that it is that hard to see intentional...however...the coordination between all of the refs, field crew, knowing which bot to shut off is difficult. at IRI we had probably the best ref crew and scoring/match running crew available in FIRST AND they were right next to each other. Andy was rarely more than 8 ft from Ken and the rest of the scoring table and they still had problems coordinating which bot to turn off at times. not because it is hard, but because it's a noisy, action-packed two minutes and the refs don't want (and the fans and scorers don't want) to have to scream at each other during the match to constantly disable robots for different amounts of time. let the refs watch the match...then make the call. if it needs immediate attention (few things do but it happens) they can take care of that. but let them do their job without having to get that complicated
Headsets?
MrToast
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
2004 IRI (Indiana Robotics Invitational) Chris Fultz Off-Season Events 147 24-04-2007 23:33
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
2004 IRI Music Thread Ryan Dognaux Off-Season Events 86 06-07-2004 22:49
Announcement: The 2004 IRI Talent Show! Amanda Morrison Off-Season Events 22 10-06-2004 01:33
White Paper Discuss: 2004 IRI Description and Details CD47-Bot Extra Discussion 1 12-05-2004 16:03
