Go to Post The honor from any given job is not so much what you are doing, but how you do it; the hardest working garbage man deserves more honor then the laziest super hero. - Josh Hambright [more]
Unread 16-07-2004, 14:50
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Dashboard Robot Controller Packet Info??
Hi,
Writing a simple VB6 program to read the 26 byte data from the OI/RC view the Dashboard port. OI is easy to read and works well. RC uses three interlaced data packets.
How do I differentiate between the three data packets for the RC?
My attachment shows three packets. Depending upon when I open and close and open again, the packets move around.
Thanks,
Chuck
Unread 16-07-2004, 17:29
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Dashboard Robot Controller Packet Info??
Have you read IFI's Doc yet? it tells you everything but how to differentiate between RC and OI packets.
If you want, I'll send you a VB control to read and interprete the data.
[edit]here[/edit]
Unread 19-07-2004, 08:21
cbolin's Avatar
RESOLVED! Dashboard Robot Controller Packet Info??
Hi,
I read the spec last Friday however the means to differentiate between the frames was not explicit. However, after posting this message last Friday, I reread it a few times and finally understood the stuff that read [CTRL_C Bit 7=0, ...]. Did some bit operations first thing this morning and everything is working fine now. :-)
So, it is necessary to read two specific bits in order to figure out which of the 3 frames are being viewed.
Byte 8, bit 4 and Byte 12, bit 7. The frames are then recognized by the following pattern respectively.
Frame 1 = 0,0
Frame 2 = 1,0
Frame 3 = 1,1
The code to read the values went like this. sRec stores the string of 26 characters.
nA4 = Asc(Mid(sRec, 8, 1)) And &H10 'byte 8, bit 4
nC7 = Asc(Mid(sRec, 12, 1)) And &H80 'byte 12, bit 7
Astronouth...I appreciate the offer for the 'control' to do this for me, but the fun in all of this programming is to write the code myself.
Thanks,
Chuck
Unread 22-07-2004, 15:07
AKA: Jamie Bliss
Re: RESOLVED! Dashboard Robot Controller Packet Info??
it's open source. An ActiveX control. I can almost garentee you're already using one. The MSCOMM control.
BLOWN COMPONENT! In need of 2004 Robot controller to borrow for 2 days Michael Luedtke Electrical 9 22-02-2004 22:15
New dashboard packet spec Ameya Programming 2 08-01-2004 19:59
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
delta_t data in Robot controller GreenDice Technical Discussion 3 06-01-2002 08:32
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
