Go to Post I have to wrap my brain about a robotics team named Dudettes. I can get there but ... I need coffee. - JaneYoung [more]
Unread 18-07-2004, 16:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
PWM Cable Clip for Victors
Cool product: http://robotcombat.com/marketplace_ifi_esc2.html
Unread 18-07-2004, 16:23
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: PWM Cable Clip for Victors
I never knew something like that existed! We've had the PWM cables come loose more than a few times. At least with them being stainless steel they won't rust and with almost no weight adding them shouldn't be an issue. The price is also very reasonable and a good insurance policy for not having to worry about losing a cable in the middle of a match. I might even buy some of them and donate them to my team.
Now the big question, I wonder if FIRST is planning on including some of them in the KOP for next year.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 18-07-2004, 16:26
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Excellent find, before we ended up gluing in the connectors, but that way we were unable to change cables or take them out. This could be very handy, might even look into machining them, doesn't look too hard.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 18-07-2004, 16:46
I think it would be more of a lasercutting/waterjet and bending type of thing with sheet metal rather than machining out of a solid block.
Unread 18-07-2004, 16:54
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Or...
you could probably make one with some sheet metal, a pair of tin snips, and a ruler.
snip, snip, bend bend.... done.
Unread 18-07-2004, 17:20
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
That's a very good idea. Our team had one come out right when we were about to hang this year, preventing us from doing so. Thanks for the link...I"m definetly going to look into making some of those this year.
Unread 18-07-2004, 17:25
Joshua May's Avatar
Go Bears!
Originally Posted by JVN
Or...
That's more what I was talking about. Aluminum or steel sheet, band saw, pliers, and some goood ol' elbow grease should do the trick.
Unread 18-07-2004, 17:46
Billfred's Avatar
Billfred Billfred is offline
I recall seeing those at one point. They seem pretty useful, especially if you've got to attach Victors a ways away from the robot controller.
On the other hand, a good whack can still spell disaster for those cables. Maybe it'd be simpler/cheaper to zip-tie the PWM cable to the Victor, then screw the Victor to the robot. With the zip-tie put inside the screws, your cable is going nowhere fast. (And you can always use a pin and defeat the ratchet if you have to switch cables.)
Perhaps we FIRSTers could learn a trick or two from the Battlebots set. I mean, we both have to come with a pretty durable machine, given how things get on the field. (Of course, the intent of the way things get is different, or so we hope!)
(I'm reminded of a trick I once read where a person used a zip tie to hold the battery connectors together. Not once was there a problem.)
Unread 18-07-2004, 18:26
There might not have been an actual problem but that "solution" presented a large potential problem. If the battery had to be unplugged quickly because of short or other dangerous situation, it would be bad news for whoever is trying to unplug it. Velcro strap is much better. But, I suppose this discussion should be left for another thread.
Unread 18-07-2004, 19:27
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
That little clip is cool, but that whole site is amazing. This another one of those times that I feel stupid for not thinking to search for a site like this. The site has lots of other stuff that is exactly up our alley. Small gearboxes designed for our purposes. Wheels, and lots of other good stuff. Everyone should definitley take a look. I definitley see a couple of parts that my team may very well be using.
Team 1257
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
Fading LEDs using a PWM signal from the Edubot DanL Programming 22 30-03-2004 00:07
Female PWM cable connector Paul Marshall Technical Discussion 3 19-02-2004 12:10
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
