Go to Post Never be afraid to admit your ignorance, and ask someone something. You may just learn something new... - kmcclary [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations
Unread 15-07-2004, 23:57
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
[FVG]: Difficulty Levels
i know this doesnt need to be decided right away, but i figured why not start now? we need to decide some things:
  • how many difficulty levels we want to have
  • which are available from the beginning and which must be accessed
  • has anybody noticed how much i love the list code?
  • what we want to name the different difficulty levels
Unread 16-07-2004, 14:04
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Re: [FVG]: Difficulty Levels
We should start off with 3 diffuculty levels:
  • Rookie == easy == limited AI, a few smart moves by the computer, etc.
  • Veteran == norm == good AI, more smart moves, etc.
  • Expert == hard == extremely good AI, makes very smart moves, able to predict opponets moves, etc.
    I am tempted to put a 4th, harder level of difficulty, but these three will do.
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 16-07-2004, 14:45
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Rookie Mode
Normal Mode
13 Year Veteran Mode
Dean-Like Mode
Purdue Alumni
Cummins, Inc.
Unread 16-07-2004, 15:11
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
The only problem with the difficulty being the AI is, well, that AI is hard to do, expecially considering that there will be dozens/hundereds of robots that the AI might have to handle, each with different capabilties/stregths. Also, the field isn't very static, meaning there are balls bouncing around, other robots... All in all, AI will be the hardest part of the project (after we get the framework up, of coures.
A better idea might be to make the different levels give your particualar robot various levels of "handicaps." For instance, on rookie, your robot might be able to always climb the platform (assuming it's so equipted). Also, HP accuracy is something easy to write that could be used.
Unread 16-07-2004, 15:16
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Originally Posted by Clark Gilbert
Rookie Mode
Normal Mode
Dean-Like Mode
Perhaps not "Dean-like Mode" but simply "Dean Mode". That would be amusing
MrToast
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 16-07-2004, 17:13
i was actually thinking it should be:
Rookie
Veteran
Expert
Gracious Professional
Unread 16-07-2004, 17:35
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
A given AI will only support a given set of bots.
I've been thinking, and here's how it goes:
  • The AI is sepperate from the robot (malicious code)
  • The AI recieves info on the robot's speed, position, orientation, and the feed back data.
  • The AI outputs an OI packet
  • The packet is screened before going to the bot (malicious code)
The goal is to prevent an AI from interacting directly with the robot (preventing cheaters), but allow the AI to be easily made and quickly ran.
Unread 16-07-2004, 20:04
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
I think the levels should be:
Preseason Scrimage - barely functional opponents
Early Regional - half of Opponets work and little strategic play
Late Regional - 3/4 of Opponents work and play strategically
Championship - all Opponents work and play strategically
Christopher H Husmann, PE
"Who is John Galt?"
Unread 16-07-2004, 20:29
Nastay's Avatar
Nastay Nastay is offline
Jim Smith
AKA: Jim Smith
#0236 (Techno Ticks)
Nastay is an unknown quantity at this point
Send a message via AIM to Nastay
I was thinking that one way we could change the AI would be to add time delays to when the AI receives/can use and react to the other robots. So hard, when you moved the AI would know almost immediately and be able to react to you and prevent you from doing something faster, where as on easy maybe add a few tenths of a second to that, so it would be like the AI driver had slow reflexes... just a thought.
First Video Game! - Port Leader
sudo rm -r -f -v /
Nastay
21
Unread 16-07-2004, 21:02
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
If this is the case, then each robot would have to include a ranking of its strengths and weaknesses (e.g., more defensive, better hanger, etc.). Note that it would be rather complicated, and not necessarily very effective (esp. for time put in) to do it this way, -- at least at initial inspection. It seems to me, though, the computer AI needs just be a generic bot (maybe have several based on different strengths/weaknesses), but the AI seems very much a property of the bot. Of course, and this is a BIG of course, it is waaaaaaaaaaaaaaay to early to really be discussing any of this seriously. The AI can wait, because it is all for naught if no energy is put into the basic structure, the very backbone of the game. What will the competition framework be like? How will matches be handled? Start thinking in terms of:
Basic element is Robot, of which two constitute an alliance. 2 alliances passed to Match, which returns winning alliance. List of Robots passed to Tournament, which includes a Scheduler which gets all the pairings and timing set up (a fair amount of thought needed if you allow many players across a network connection; for instance, it seems heuristic methods for a "bin packing" problem might be needed--but now I commit your sin and digress ). Tournament includes Scheduler, some Referee element (makes sure all stay in field, robots aren't hit too hard, pinning limited, etc.), a Scorer(for Match, and then one for Tournament), which scores the match and some way to record the running score of the whole tournament. Etc.
There's a bunch more elements like this. I may have even been too specific; it helps to start out with general outlines like such, so everyone is thinking of the same thing, ...and so that once it is fleshed out more, elements like AI Design can be tackled in turn and everyone can see what they might be able to add discussion to, etc. Of course, ignore my poor example and just use it as a general springboard for thought, not necessarily a suggestion for your particular structure--which I can't even begin to make, as I don't know many basic things that need to be decided first ... e.g., do you plan to allow multiple players through network connections eventually? if so, should know so you can plan for it now ... do you plan to play through a whole tournament season, and then go to nationals perchance, or just a single match or a series of matches? ... etc. You can see, I hope, that the basic questions must needs be discussed, so that the basic structure can begin to be discussed, so that the more specific elements can be discussed, so that algorithms and pseudocode can be created, so that eventually you can program the darn thing. (Disclaimer: Some steps missing.)
Unread 19-07-2004, 08:26
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
I like those three for the first three levels. If adding in a fourth level, it should only be available after beating the whole third/expert level - kind of like a secret level.
Unread 19-07-2004, 11:00
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Sorry for tossing in my two cents without reading all of the threads about the video game. Maybe this has already been discussed, but wouldn't it be great to be able to help another team in the pit area, have alliances congratulate eachother, etc? In short, if you REALLY want a game about FIRST, then it needs to be something other than just the game. These things could be done with a combination of text and simple objects without actual people to model if that was too hard. OK, I'm done. Congrats on a great project and good luck.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 20-07-2004, 12:35
Programming User
Cool idea. For the first versions, we'll probably just go for game play, but maybe after we get that working well, we can have break downs, with a few decisions on what you should do...
We might also be able to have a few scenes created in 3DS showing one team congratualting another. Obviously you couldn't do all of them, but, you could do some...
Unread 22-07-2004, 15:25
AKA: Jamie Bliss
A built-in pit chat? maybe...
some clips from various comps would be cool. Also: if you're in the pits, how about watching the game?
(This is all for LAN/Web play, of course).
[FVG]: Produced Materials Mike Ciance FIRST-related Organizations 31 05-07-2004 17:41
[FVG]: Robot AI Mike Ciance FIRST-related Organizations 7 04-07-2004 14:35
[FVG]: Menus Ryan M. FIRST-related Organizations 29 02-07-2004 18:58
[FVG]: Opening Sequence Joshua May FIRST-related Organizations 16 24-06-2004 00:00
Can someone list the poster levels mnkysp6353 CD Forum Support 1 10-02-2002 22:14
