19-07-2004, 11:40
Re: Competition Port
Originally Posted by roboticsguy1988
Ok, I have two questions about the competition port pins.
First, we are working on an older robot for a demo. We have the choice between year 2000 OI and year 2002 OI. Both of course didn't have autonomus back when the were made. So if i were to make a disable switch would it use the same pins as it does on the newer OI's? We were thinking about letting some people out of the crowd drive the robot to have some fun, and we thought it would be safe to have a disable switch.
Second, are there any pins on the competition port that put out power? If so, do you know how much voltage it puts out? I had the idea of putting some LED's in a clear switch box (auton, disable, practice), kinda to make it glow  . Also, what pin should i use for the ground of the LED's? By the way, this information i would want for the newer OI's.
Thanks,
Larry Johnston
Since these are old, if you can't figure out the pins, would it be possible to make a disable function in the program itself? (forgive me, i'm new, I don't even know if you did a lot of programming back then).
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
