Go to Post I was watching the webcast when that score was posted and thought to myself, "What did they do, steal a donut from Dave?" - MissInformation [more]
Unread 19-07-2004, 13:54
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Competition Port
Originally Posted by Dave Flowerday
It's been a while since we tried it, but I'm nearly certain that pre-2003 OIs would actually accept the autonomous switch, and even send the autonomous signal to the robot (i.e. you can use 2002's OI to control a 2003 robot, with autonomous and everything). The only difference is that you won't see the rapid flashing of the disabled LED that indicates autonomous mode on 2003's OI.
I thought that a 2002 model needed a firmware update to support autonomous mode. Weren't the 2002s physically identical to the 2003s, but needed to be sent back to IFI for reprogramming if you wanted to do autonomous (introduced in 2003)?
Unread 19-07-2004, 15:49
I remember the firmware update to the '02 version wasn't necessary for passing the autonomous bit itself. That was just one of the "growth" bits IFI already had reserved for future use and was already passed but not used for anything in '02. I believe what the firmware update changed was to actually cut off access to the OI inputs while the autonomous bit was set, e.g., the Joystick values were all forced to 127, etc.
You might have to take into account that the OI control values will still be passed, for instance, by explicitly setting the OI inputs to neutral values at the beginning of your autonomous section of code. Then again your autonomous code probably will be ignoring those values anyway.
Unread 19-07-2004, 20:34
Pin 1 on the competition port is hooked directly to +5 on the OI.
However doing so will void your warranty. Pin 8 is ground.
Unread 19-07-2004, 22:05
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Wink Re: Competition Port
Ok, thank you. I have the disable switch working, and i am going to probably hook up the LEDs later.
Thanks,
Larry
Unread 19-07-2004, 22:09
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Thanks,
Larry
I still would suggest you make an led circuit run off of a 9 volt battery. If you do run the leds off of pins on the oi's comp port and any damage done in the future or and work you would like done to that oi, including upgrading firmware can be rejected by ifi even if your paying for it due to you fooling with the pins. Your choice should be thought about before you play with "fire" by running leds off of the comp port.
-Michael Dessingue
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
New Competition in MI, Mailing List Allison K Off-Season Events 0 29-03-2004 19:53
Robots prepped for competition Brandon Martus FIRST In the News... 0 24-03-2004 17:06
wire from competition port? rocko Electrical 7 07-02-2004 23:22
How well did the regional competition help preparing? archiver 2001 3 24-06-2002 02:33
