Go to Post "I would love to change the world but no one will give me the source code" - programmr [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations
Unread 20-07-2004, 16:54
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
[FVG]: 3ds field model
Hey! 3D people... Do we have a model of the 2004 (any year really, I don't care) game field already? (I know that several people had made these.) It doesn't have to be good or anything, I just would like to see if a program that I have can convert it to the correct CS map file. If you have one, post or PM me...
There are also rumors (from the CS website) of a plugin for 3ds that allows it to output CS map files directly. There wasn't a link, but if you'd like to look for it...
Unread 20-07-2004, 16:59
Dorienne's Avatar
Dorienne Dorienne is offline
6 years and counting! :)
AKA: the only fish in FIRST
FRC #0007 (Team 007); FRC #1719 (Umbrella Corp)
Dorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond repute
Send a message via AIM to Dorienne
Re: [FVG]: 3ds field model
I think they do, I'll check through the other threads and find it.
I can't remember who did it.
--d0ri
Have you found NEMO yet?
Proud mentor to teams 007 and 1719!
Unread 20-07-2004, 17:03
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
I've got it, http://hhsrobotics.circuitrunners.com/FVG/test.png. This is what is done so far, still needs some work, however.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 20-07-2004, 17:04
Dorienne's Avatar
Thanks much!
Made my search easier
--d0ri
Unread 20-07-2004, 17:32
Programming User
Could you get me the actual 3ds file? Not just a rendering... But looks good.
Unread 20-07-2004, 19:44
-PauL-'s Avatar
-PauL- -PauL- is offline
#0230 (Gaelhawks)
Team Role: Animator
-PauL- will become famous soon enough
Send a message via AIM to -PauL- Send a message via MSN to -PauL-
there are fields, but theyre horribly high poly, you dont want them. people need to learn that if you make a circle with 50 sides, or over boolean something, sure it lookes perfect, but it runs bad.
Unread 20-07-2004, 21:42
Joshua May's Avatar
Go Bears!
Sure, I'll upload it soon.
Unread 20-07-2004, 21:46
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Contact THIS team for info about the 3D field that is found HERE.
Good luck.. Those are the only 3D field pics I have ever seen online (for this year anyways)..
Unread 20-07-2004, 21:58
Joshua May's Avatar
Go Bears!
Allright, here is the zip file that contains the *.max file and the textures.
To get the textures to work, you may have to place then in the same folder as on my computer, which is C:/3dsmax5/scenes/
EDIT:
Very nice textures, I'll have to look into that raytrace program.
Unread 21-07-2004, 03:54
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
I haven't posted in this forum before, but I decided to go ahead and start somewhere.
I was working on getting these to work this morning::
(I have compiled CS, but I have not read the docs farther than installation, so I was using Irrlicht)
.max 2004 FRC field, download and use!
Field 3D model, any takers?
I had tried to convert both of them to Q3 BSP models, but I couldn't figure out the 3ds2map program.
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 21-07-2004, 17:17
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
i dunno, it looks to high-detail for this game. we want this game to run well on most computers and a high-detail field will slow it down. the one HHSJosh is working on is almost done anyway.
i could be wrong, i mean i don't know the poly counts on these things, but i think HHSJosh's model would run better.
Unread 22-07-2004, 15:39
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Is there any way in 3DS Max to keep curves as curves? Because if both CS and 3ds use it, the quality can be user adjustable.
Unread 23-07-2004, 02:34
Everyone who is looking at this post may already know about this site by now, but just in case you don't, THIS SITE has a bunch of CAD models and whatnot of various FIRST stuff from over the years. It may help.
Unread 23-07-2004, 14:20
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
I can provide you with some higher-detail textures for the field model if you need them.
Here are some renders of the field model we used for our animation entry:
http://web.mit.edu/~levpopov/Public/FIELD/f01.jpg
http://web.mit.edu/~levpopov/Public/FIELD/f02.jpg
If you want to have very detailed looking field while keeping the polycount low, i suggest baking in most of the lighting and shadows. Yes, it may produce some unrealistic artifacts like wrong shadows or reflections, but in my opinion its still a lot better than just flat color.
Unread 23-07-2004, 15:33
Programming User
Those are pretty good looking (well, great ).
Ater we manage to get a conversion of one of the maps, we'll see how it runs. Then we'll decided what sorts of things we may/may not have to do without.
==EDIT==
If someone would like to help me out here, there is a CS export plugin for 3ds available at http://www.freesoma.org/. I don't know what version you're using, but the pludin says it's for 4.2. Hopefully, it will be backward compatible, and you can get that to work... If anyone manages to convert a map (I don't care which), please PM me, or post back here (or both).
See the playing field in 3D Glasses General Forum 2 20-06-2005 20:57
Playing field model Leez0r 3D Animation and Competition 9 16-02-2003 14:16
Image Discuss: my field model CD47-Bot Extra Discussion 5 01-02-2003 15:10
MaC Rhinoceros field model error? Jeff Sharpe General Forum 6 26-01-2003 22:33
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
