Re: Cold heat?
I just saw it today on thinkgeek: http://www.thinkgeek.com/gadgets/tools/69d3/
Re: Cold heat?
About the car wax, my uncle worked in show biz and he once shot a commercial for some car wax, and right before take 1 they were waxing the car with the wax they were going to sell and it just would not shine. So they had to run out and buy some Simonize wax to shine the car that would be selling the cheapo wax.
Re: Cold heat?
No Ted didn't use the soldering gun on his cousins.
We stocked up on duct tape and cable ties. |
Re: Cold heat?
I have one and it works fine. My team used it on every soldering job we had.
Re: Cold heat?
my son got one - it does work
but the tip has to maintain electrical contact on both sides of the tip for it to heat and as someone else said, there is voltage present across the tip (I dont know how much) I like my Weller. Never yet grabbed it by the wrong end and burned myself. And Ive never NEEDED to stick a soldering iron in my pocket 3 seconds after using it. If you need to cool an iron quickly you simply wipe it with a wet sponge or paper towel. Neat product, but I thinks its a solution in search of a problem. |
Re: Cold heat?
Re: Cold heat?
I've used one.
It does work- it heats up quickly and cools down quickly. You can even solder with it. The problem is that it's pretty useless for doing more then quick fixes. It heats up quick, but it has so little thermal energy that youd be sitting there for an hour trying to heat up a large joint enough to get solder to flow properly. So don't even bother trying to solder up a crimp connector. For small PCB stuff, it's pretty snazzy. I wouldn't want to do more then a few joints with it though. An electric iron may take a few minutes to heat up, but once it does it will stay hot for as long as you want. It may seem silly, but waiting those few seconds for the coldheat to warm up is annoying. I'd say its not overly useful for FIRST, but it could be handy for the average joe. It certaintly is a lot faster and easier then a butane powered iron and more portable then a corded. There is more concern with keeping it clean, as solder stuck on the tip fouls it up right quick. -Andy A. |
#8
Re: Cold heat?
We have one, but I didn't like it. It is true to its word of heating up and cooling quickly, but metal must be in the little slot for it to work. It might be good for small jobs around the house, but I did not find it very useful for robotics.
#9
Re: Cold heat?
Re: Cold heat?
Re: Cold heat?
I'm not exactly sure how it works, but there is a spark somewhere in the thing and that's how it gets the solder hot. however, there is still a possibility of you burning yourself with this iron. my team decided to stay away from this and stick to the normal irons. according to one guy, this thing is also hard to get into small places. http://www.msnbc.msn.com/id/6151688/
#12
Re: Cold heat?
and with such a small tip it may take a lot of heating to get a good joint with bigger wires |
#13
Re: Cold heat?
or a propane / butane torch. |
| 'IT' info... | archiver | 2001 | 19 | 24-06-2002 01:58 |
| Team heat wave is on fire!!!!!!!!!!!!! | archiver | 2001 | 3 | 24-06-2002 01:38 |
| Cold in a Can | archiver | 2000 | 8 | 23-06-2002 22:17 |
| New IT info? | Mike Soukup | Dean Kamen's Inventions | 10 | 08-12-2001 23:03 |
| heat gun | Lake Orion | OCCRA | 2 | 21-10-2001 23:34 |
