Go to Post Ship day is a sweet and sour day. You're happy to see your robot ship, but then you start going through robot withdrawl - Schneidie [more]
Unread 24-07-2004, 01:08
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
ANSI 25 Sprockets in CAD
I've searched around with no success. I'm looking for ANSI 25 sprockets in cad. We're looking at ANSI 25 roller chain for next year and if we can get CAD drawings we might be able to get aluminum sprockets made when build time comes (yeah, I'm ahead of myself, I know). Thanks
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 24-07-2004, 02:46
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: ANSI 25 Sprockets in CAD
There's a few here: Sprockets
If what you want isn't there, let me know how many teeth - hubbed/hubless - finished/plain bore and I'll model a few for you.
Unread 24-07-2004, 12:14
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
They can also be found on www.cadregister.com
in the partspec section look up sprockets, then Berg as the manufacturer
then the ansi 25's are also refered to as 1/4 pitch
you'll get a 2d face profile with a couple teeth that you'll need to array at the needed teeth.
www.179swampthing.org
Unread 24-07-2004, 13:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
There's one here http://www.cbliss.com/inventor/Parts.htm I don't know if they have the size you need but it is worth a try.
Unread 25-07-2004, 11:15
Thanks, your replies have been helpful. If anyone finds more, send them my way.
I'm no good at CAD/Inventor (yet) so I'm wondering how difficult it would be to use one of these to CNC Mill a flat stock of 1/8" aluminum into a sprocket that would attach to a hub. I want to do it that way so we don't have to spend $$$ on inch thick aluminum that's just going to get shreded. Is it possible to output the CAD design to a CNC Mill program?
www.burobotics.org
Unread 25-07-2004, 16:24
Retired
I'd recommend you water cut them. All you need is as input is a .dxf line drawing.
Also, #25 chain has a 1/8" roller width, so 1/8" Al is a little too thick; it's likely to bind.
Unread 26-07-2004, 10:37
I'm not sure if we have access to water cutting, and if so how easily they'd let us use it. That's a great thought though, I'll have to look into it. So that I don't sound like a babbling fool (hard to achieve) what would I call the machinery? Water-Cut-O-Matic 5000? That'd be great. In other words, will they understand when I say water cutting? Thanks
1/8" would be just fine I believe. All that is needed is to put it on a lathe and add a small pitch, right? We did this with sprockets we had made last year.
Incase last year's sprockets make you wonder: they were ANSI 35 for starters and we had the kits drawings I believe. Also, it was done as a last minute favor by a large machine shop on campus and if I'm not mistaken, they did it all by hand (i.e. not water cutting or CNC Milling). It took them over a week working full time to make 5 sprockets, so I'd really like to be more efficient
www.burobotics.org
Unread 26-07-2004, 10:57
There is also the option of laser cutting. Also, a water cutter is often referred to as water jet.
Unread 26-07-2004, 17:02
cmaccoy's Avatar
cmaccoy cmaccoy is offline
FRC #0173 (R.A.G.E.)
Team Role: Student
cmaccoy is on a distinguished road
Send a message via AIM to cmaccoy Send a message via Yahoo to cmaccoy
Do you actually have any Cad/cam software? I'm good with MasterCam. And if you actually have that...........i can help you...
~cmaccoy
F.I.R.S.T. My anti-drug
sprockets from mscdirect Max Lobovsky Kit & Additional Hardware 5 29-01-2004 23:59
First cad parts library wayne 05 Inventor 11 08-12-2003 21:00
First Logo as a CAD file jrgrim12 Inventor 4 14-02-2003 11:42
modifying sprockets gail OCCRA 3 05-10-2002 12:13
CAD Drawings? archiver 1999 17 23-06-2002 22:35
