Go to Post work? I can't remember when the last time i did that was... - Carolyn Duncan [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 07-04-2002, 17:20
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Well, the 70 lbs. limit may also be related to the maximum amount of cargo an aircraft can hold, and how that relates to each individual passenger.
But, otherwise, just use common sense.
If, by chance you're flying Delta (as we are), this may be of some use to you:
http://www.delta.com/cwswaittime/tra...time/index.jsp
Orlando Int'l Airport's code is MCO. You're own your own for local airports. I'd probably expect it to take a bit longer than what's posted, but I have no real clue as to how accurate their numbers are.
I don't know if other airlines have anything similar on their websites.
Finally, I'd heard that they make you turn on any suspicious electronic equipment to prove that it is what you say it is.
--Madison--
...down at the Ozdust!
read and write command rosebud Programming 3 26-03-2003 19:44
Marking forums read David Kelly CD Forum Support 6 15-05-2002 14:50
Have You read the rules? RonP General Forum 0 21-01-2002 17:55
Please read and look at web site Amadkow Chit-Chat 2 01-11-2001 14:37
'read' posts that arent read mike o'leary CD Forum Support 4 10-06-2001 11:29
