Go to Post There are zillions more volunteers than paid staff. We are FIRST. - Rick TYler [more]
Unread 29-07-2004, 11:55
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Automatic Shifting Algorithm
For the purposes of this thread we are assuming that the robot has a four speed transmission.
In 2005 I'd like to have a fully automatic transmission, but I've been struggling with how I'd actually implement this (from an algorithm standpoint).
This is the best I've come up with:
Find max speed robot is capable of in highest gear with full motor power. Call this x. Using banner sensors, the speed of the wheels will be used in the algorithm as a percentage of x. The percentage of joystick input would the correlate directly to the speed of the wheels. The algorithm would increase motor power until reaching the desired wheel speed unless it hits 255 first at which point it would shift up and decrease motor by some given amount calculated ahead of time.
I really have very little idea what I'm doing
How would you do it?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 29-07-2004, 12:20
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Smile Re: Automatic Shifting Algorithm
*Warning this is coming from a person who also has a vague idea what he is doing* I would try and forgo providing any imput from the joysticks. The whole purpose of an automatic transmission is that you can jam the pedal all the way down without having to worry about destroying the motor. I would focus on the wheel speed only. At 0-X1 the gearbox would be set to to the lowest gear. At x1-x2 the gearbox would shift up. At x2-x3 the gearbox would then again shift up. At x3-max speed the gearbox would be at it's final speed. The x's represent the maximum speeds that the gear transmision would obtain. So in my eyes it would be a simple inequality.
If speed is greather than 0 but less than X1 shift into lowest gear ratio.
If speed is greater than X1 but less than X2 shift up into second gear.
If speed is greather than X2 but less than X3 shift up into third gear.
If speed is greater than X3 or equal to max speed shift into forth.
Unread 29-07-2004, 12:55
phrontist's Avatar
Proto-Engineer
The system you described is what I was thinking, sorry if my explanation indicated otherwise.
Ah, but the problem with this is that it almost defeats the purpose of a tranny! What if you go up a ramp or get into a shoving match? It seems more logical to have a system like the one described but also have it check the current draw on the motors. If the current draw is more then y (and y would have to be found through tinkering) don't shift up to go faster, shift down.
I think that would work...
Unread 29-07-2004, 13:02
Adam Y.'s Avatar
Adam Y.
no team (?????)
No problem.
Good idea. I was thinking that the banner sensors wouldn't be reliable enough to use in an automatic transmission. Now you would have redundancy built into the system.
Unread 29-07-2004, 13:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Why not measure the RPMs of the motor and up/downshift as necessary?
IE:
// Globals
long RPM;
#define MINRPM 10
#define MAXRPM 100
unsigned char Gear = 1;
#define MAXGEAR 4
#define MINGEAR 1
// in some sub...
if (RPM < MINRPM) Gear--;
if (RPM > MAXRPM) Gear++;
if (Gear < MINGEAR) Gear = MINGEAR;
if (Gear > MAXGEAR) Gear = MAXGEAR;
// change gears, if necesary
[edit]This is all asuming the code can shift well and measure rpms acurately enough[/edit]
Unread 29-07-2004, 13:49
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
I would suggest shifting based upon the torque, not the speed. The problem is that torque is more difficult to measure than speed, but you can do a decent job using current sensors.
The algorithm would look something like:
if (torque > DownShiftThresh)
    Gear--;
else if (torque < UpShiftThresh)
    Gear++;
if (Gear > 4)
    Gear = 4;
if (Gear < 1)
    Gear = 1;
Shift(Gear);
Unread 29-07-2004, 13:52
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Yes, but if you get into a pushing match, wouldn't you slow down anyways, causing it to shift down?
-Paul
Unread 29-07-2004, 13:59
Adam Y.'s Avatar
Adam Y.
no team (?????)
I suggested that in the second post. The only problem is that you would need a fairly reliable sensor to accomplish this. Hmm... I have an idea. A really cool idea that might just work. Ill be on later.
Unread 29-07-2004, 14:37
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
You might also want to include a sort of "buffer"... if for some reason your robot is fluctuating speeds from just above and below "x2", then it'll be constantly engaging the shift back and forth... probably not the healthiest thing.
Joules per second! Watt? Joules per second! Watt? Jouls per second! Watt?
Unread 29-07-2004, 17:50
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
We used banner sensors for ours and they worked fine. We used four, two per tone wheel, one tone wheel per side. They doubled as encoders for autonomous and gave us the ability to make our robot go anywhere on the field within about an inch. Our design for next year actually uses a shaft encoder right in the gearbox. It'll be in the whitepaper, I posted a picture of the CAD drawing somewhere.
So....just use a shaft encoder.
-Paul
Unread 29-07-2004, 22:47
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
This "buffer" is called hysteresis. Before shifting up, you should wait until the RPMs/speed is "a little" above your threshold, and before shifting down, you should wait until it is "a little" below.
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
Slotted Nuts and Shifting sanddrag Technical Discussion 6 07-03-2004 13:04
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
gear shifting Stephen Kowski Motors 19 30-03-2003 21:33
Arcsin Calculation Algorithm Leo M Technical Discussion 11 05-11-2001 08:31
