Go to Post Right, play to win. Play to win the event or play to win one match? This year, unfortunately, they are not the same thing. - Paul Copioli [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 30-07-2004, 15:02
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Speaking of PHP 5...
Well, the title is in reference to the openFIRST thing about compatibility.
Anyway, my real question is: I have it set up (PHP 5) to supposedly load the php_mysql extension. However, when PHP is loaded, (it's configured as a module for Apache 2) it gives me a "unable to load php_mysql.dll" error.
Any ideas about what this might be/an example of loading MySQL as an extension to PHP would be appreciated.
Unread 30-07-2004, 15:09
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: Speaking of PHP 5...
Hello,
I had enough trouble with the same problem early on (with PHP5b1). One thing that I had forgotten to do was to place libmysql.dll and libdb.dll in the Windows System (or system32, based on OS) directory.
Another thing to make sure is that php.ini (in the windows or winnt directory) has the MySQL extension enabled. By default, it is commented out.
Finally, try running Apache in console mode, as opposed to service mode. You will see dialogs when (and if) PHP can't find files or dlls.
Good luck
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 30-07-2004, 15:26
Programming User
Thanks to Vankatesh. Got it working...
Unread 01-08-2004, 16:46
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
Congratulations,
Just a heads up, if you're having issues with anything now that you've moved to PHP 5 this is worth a read:
http://www.php.net/migration5
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
openFIRST PHP 5 Compatibility Timothy D. Ginn FIRST-related Organizations 0 30-07-2004 13:45
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
PHP Question Raven_Writer Website Design/Showcase 2 22-05-2004 18:42
php vs. perl Jack Website Design/Showcase 20 29-12-2002 17:01
What's better, PERL/cgi or PHP/my_sql? mikefrei Programming 10 27-05-2002 22:50
