Go to Post First'ers aren't 'normal' I guess. Whatever that word means now a days - dancingfool [more]
Unread 02-08-2004, 14:06
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Using the Microsoft Sidewinder Controller
Here are the specs for DB15 game port:
Pin NonMIDI MIDI IFI
 1   +5v    +5v  +5v
 2   A-1    A-1  Trigger
 3   A-X    A-X   X
 4   Gnd    Gnd  Gnd
 5   Gnd    Gnd  LED/Switch
 6   A-Y    A-Y   Y
 7   A-2    A-2  Thumb
 8   +5v    +5v  LED/Switch
 9   +5v    +5v  LED/Switch
 10  B-1    B-1  Aux1
 11  B-X    B-X  Aux
 12  Gnd    Rx   Gnd
 13  B-Y    B-Y  Wheel
 14  B-2    B-2  Aux2
 15  +5v    Tx   LED/Switch
Notice that pins 5, 8, 9, & 15 are special on the OI.
I would recomend hooking it up to an OI/RC that are just sitting there and looking at the dashboard. This may give you clues as to what goes where on a Sidewinder. Also, hook up an oscilliscope (if available) to the Rx/Tx pins and see what level/baud it uses and which way they go.
Unread 02-08-2004, 15:05
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Most (if not all) Sidewinder joysticks use a serial protocol that will not work with the IFI equipment. They end up using one of the button signals as a data line and another button signal as a clock. They then send a serial stream of information containing all the information about the analog & digital readings of the joystick over these pins. This is the reason that they warn you that the joystick will not work with MS-DOS - it requires a special driver to decode the serial stream, and there isn't one written for MS-DOS.
Microsoft Visual SourceSafe Madison FIRST-related Organizations 7 13-10-2004 21:18
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Any pratical use for Microsoft Visual Studio .NET Pro Kyle Fenton General Forum 11 28-01-2003 16:59
