Go to Post I think with so many facets of FIRST, success comes from learning the true meaning of teamwork through working towards a common goal. - Kristina [more]
Unread 04-08-2004, 00:39
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
Re: pic: 2004 TechnoKat gearbox
A chip and a Fisher Price?!? Talk about Power! I hope that it was only for tank drive.
During the 2002 season, 461 made a set of crab-treads (a great drive train, before considering weight), where two were powered by one chip each and the other two were powered by a FP and a Drill each. The FiP didn't work well, since it had plastic gears that couldn't handle competition torque. We ended up just using the drill, and the drive itself worked pretty well. I will look into getting an inventor/auto-cad file for the teams who think they can do four systems (what we did) in less than 50 pounds. A word of advice: while it may seem "cool" and "awesome" to put a 50 pound drive system, the frame better be welded, thin-walled box aluminum and the arms must be light...Very light.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
Unread 04-08-2004, 03:25
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Okay so baker and koor are selling these things , soon, this leads me to wonder what marval of machining The T-Kats are gonna have on their robots this year.. I am afraid... Seriously Afraid
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 04-08-2004, 09:39
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
As always, a very nice design. I was hoping you might change your mind about sharing the fisher adapter design but I completely understand.
How much of the gearbox will you be sharing? Is the shifter the same internal rod with hex shaft? Gear types and ratios?
Andy Brockway
Team 716, The Who'sCTEKS
Unread 04-08-2004, 09:59
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
The FP adapter design worked out well for us, until we got to IRI. The needle bearing on the output shaft found it's breaking point. This is a planetary assembly that we want to sell in the future, but it needs some improvements before that is done.
I do plan on putting together a descriptive paper on this, just not all of the print details. We used the same internal hex shaft shifter. Here are the ratios used:
CIM motor: 18 tooth, 32 dp
Intermediate shaft: 64 tooth, 32 dp (mates w/ CIM gears), 1/4 face
Low gear: 15 tooth, 20 dp, 14.5 p.a. 3/8 face
High gear: 28 tooth, 20 dp, 14.5 p.a. 3/8 face
Shifter/output shaft:
Low gear: 48 tooth, 20 dp, 14.5 p.a. 3/8 face
High gear: 35 tooth, 20 dp, 14.5 p.a. 3/8 face
12 tooth, size 35 sprocket (qty.2)
Andy B.
Unread 04-08-2004, 11:09
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Great looking design Andy.
Good luck in your new business venture!
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 04-08-2004, 11:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Andy,
Any chance we could get a picture in from the (open) side? Also, I know it's early still but is there any general price area you can give us for one of these hot little gearboxes? Thanks.
Unread 04-08-2004, 22:59
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Thumbs up Re: pic: 2004 TechnoKat gearbox
I got the privilege of assembling the gear boxes that went on 45's robot this year. I learned a ton from Andy, Mark Koors and Steve Butler about how they worked and how to assemble them. They really let us students get in on building some real important parts. I new basically nothing about how to build a gear box or anything on the robot, but by the end of the year I learned how to build gear boxes, use new tools, met a ton of cool new people and I even got to drive the robot around a few times. This years gear box is really reliable and very powerful I think. I would like to thank Andy Baker, Mark Koors, Steve Butler, Alan Anderson and Amy "Prib" for teaching me a ton of new things this year and i really look forward to the next 3!
-Kyle
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 05-08-2004, 22:15
CourtneyB
Posts: n/a
nice job! I like your guyz's gear box. It loooks kool!
Unread 11-08-2004, 21:26
Matt Reiland's Avatar
'The' drive behind the drive
Andy,
If I were a betting man I would bet on the FP being changed for 2005 after seeing FIRST clearing out all of theirs from stock. FYI
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
White Paper Discuss: Team 716, 2004 Dual Speed Gearbox CD47-Bot Extra Discussion 9 20-07-2004 15:50
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 23-01-2004 20:16
pic: The Full 2004 RC?! CD47-Bot Extra Discussion 7 07-10-2003 17:19
pic: 2004 Game Revealed! CD47-Bot Extra Discussion 28 12-09-2003 12:08
