Go to Post that is one of the funniest non-photoshoped pictures of my father i have seen... - Lil' Lavery [more]
Unread 27-07-2004, 21:38
geo's Avatar
geo geo is offline
A Nuke Would Do The Job!
FRC #0865 (WARP 7)
geo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the rough
Exclamation Looking for gears from BostonGear in Inventor..
And I have checked the First CAD library, I got two 20 Diametral Pitch gears from there. However, they don't have the gears in 24 Diametral Pitch. I'm wondering if everyone has the follow gears I am looking for. Thanks.
*All gears are in 24 diametral pitch and 20 degrees pressure angle
30 teeth, 1.25"PD
42 teeth, 1.75"PD
60 teeth, 2.5"PD
12 teeth, 0.5"PD
2006 Greater Toronto Regional Winner!(with 1114 & 1503)
2002 Canadian Regional Winner!(with 610 & 781, our rookie year )
Unread 28-07-2004, 01:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Looking for gears from BostonGear in Inventor..
You may find what you are looking for here http://www.cbliss.com/inventor/Parts/PowerTransmission/
Unread 28-07-2004, 09:08
geo's Avatar
geo geo is offline
FRC #0865 (WARP 7)
I did. I didn't find any 24 diametral pitch gears. They only 20 diametral pitch.
Unread 03-08-2004, 23:02
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Try using the Ispurgear...I believe thay would have what your looking for and then some.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 04-08-2004, 02:00
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
For most purposes, I find it easier to simply use cylinders in place of actual involute teeth--it's just too difficult to model an accurate involute. (Not impossible, just messy and difficult!)
If it's for display, the teeth may look nice, but it's actually easier to just work with a cylinder with the diameter equal to the gear's pitch diameter. There's less work for the computer to do (rendering and evaluating all those faces), and it's easier for the designer to select and manipulate the part.
Like this....
(Note: that's an improved version of the Woburn Robotics 2004 gearbox....)
Unread 05-08-2004, 07:50
President, VEX Robotics, Inc.
Go to www.bostongear.com and go to the "Bostpec" tab. They have every gear in their inventory (at least I have always gotten what I have needed) as a solid model in either native form or a generic format (IGES, STEP, PARASOLID, etc.).
I just looked o the site and they do not have inventor parts native, but they do have several generic formats that Inventor should be able to import. Here is a list in order of most robust to least robust:
1. Parasolid
2. STEP
3. ACIS
4. STL
5. IGES
You will get an e-mail with a zipped file containing the solid model.
-Paul
P.S. - I agree with Tristan regarding the gear teeth. However, you should also model a version showing the OUTSIDE diameter of the gear to make sure there are no clearance issues.
Unread 05-08-2004, 10:07
geo's Avatar
geo geo is offline
FRC #0865 (WARP 7)
-Paul
Last time I went to their site to get specs and I thought they would send me the spec by mail, so I didn't sign up. Thanks for telling that.
I acutlly did creat the gears in cylinder, but I thought I might have to prsent it. That's why I need the gears.
P.S Nice gearbox!
12 in. Wheel in Inventor 7 petek Inventor 1 17-01-2004 17:53
student inventor matt111 Inventor 7 13-01-2004 17:22
Users Guide To Inventor R2K2D2 Inventor 5 11-01-2004 14:09
Autodesk Inventor Award 2002 Digo Inventor 1 24-03-2002 12:07
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
