Go to Post We are behind you 100% (more if needed)! - Clem1640 [more]
Unread 06-08-2004, 11:20
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Yaw Rate Sensor Drift?
Originally Posted by EricS-Team180
This worked great as a yaw trimmer, and OK as a "compass" - really a yaw position calculator - not a North/South direction finder.
Very helpful post, thanks!
When you say you used it as a yaw trimmer do you mean that it was used to correct the robots steering? I was thinking about this and I figured that the errors would build up to the degree that the sensors would give such faulty information that the robot would no longer be operable. I take it this isn't the case?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
