Go to Post When motors stall, bad things happen. - Rob Stehlik [more]
Unread 06-08-2004, 12:16
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: Yaw Rate Sensor Drift?
Nicely put, Mark...
We used a slightly different approach in that we built a simple proportional control with the yaw rate (as opposed to the integrated yaw position) as the input. The intent was to keep the yaw rate to a value of zero, when driving straight.
Since we had a chassis with omni wheels, this year, "straight" meant translation in any direction (in the plane of the field) without rotation. Our control inputs included a joystick for translation and a pot (with a spring return) for rotation. The output of the yaw rate trimmer was an "adder" to the rotation input. But, since the trimmer was only active when the operator was not requesting rotational input with the pot, the 2 did not fight each other...that is the rotational input either came from the pot or from the trimmer...not both.
Thanks,
Eric
Don't PANIC!
S. P. A. M.
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
