Go to Post FIRST has set me on a completely different path in life. And I'm all the better for it. - Vincent Chan [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 07-08-2004, 08:07
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
How should I create a database of real estate? :)
As the title says: How should I go about this?
Anyway, the problem is that I want to create a database of real estate. Simple, really. If only I knew PHP. And MySQL. And, preferably, I'd like to be able to manipulate the database using a web interface.
So... is there a premade software out there which I can use to edit the MySQL database and easily search and return results where I don't have to do any/minimal PHP stuff? I'm good at following directions, I just don't know it right now and am too lazy to learn unless necessary.
Yeah, I'm in a hurry, so ask questions if you're confused about what I mean.
Unread 07-08-2004, 10:19
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: How should I create a database of real estate? :)
What exactly do you want for it?? Also, what is the purpose??
If you'd like to find a script on your own, you can go here *<-- not Google -->*
Most are free (or cost very little).
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 07-08-2004, 10:24
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
Remember that if you want to use PHP or MySQL, you need a server that supports it. I am not sure if you want the database on your computer or on a web server. If you want it on your computer than use Microsoft Access or Excell. If you want it on a web server, you need one that has PHP and MySQL or similar languages and databases.
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 07-08-2004, 10:26
AKA: Eric Hansen
Originally Posted by robot180
Remember that if you want to use PHP or MySQL, you need a server that supports it. I am not sure if you want the database on your compurer or on a web server. If you want it on your computer than use Microsoft Access or Excell. If you want it on a web server, you need one that has PHP and MySQL or similar languages and databases.
You can set up a server on your own computer, for testing and not, and it doesn't even take up 50 megs to set up (for me anyways). I just used phpdev (search sourceforge.net for it). It gives you a few package options, the most basic is PHP 4 (maybe 5), and MySQL 3.2.x for only a 10 meg download.
Y!: synsoflife
Unread 07-08-2004, 12:00
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Simple: Don't.
I've done a lot of stuff with GIS and almost every municipality in the country has an online real-estate assesment database that is really easy to interface too. Google for it.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 07-08-2004, 12:41
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I'll have to agree with Phrontist. The only reason I could see you doing such a project is just for the sake of learning PHP. Actually, I take that back, I have no idea what you are doing so I can't really comment. It sounds like all you want to do is store some information and search it? Can't you just make an Excel spread sheet and put it online? Regardless, please give us more information so we can help you better.
Team 1257
Unread 08-08-2004, 18:44
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
As far as creating the MySQL Database and adding and editing items in it, phpMyAdmin works great. However, you have to script your own interface (or there might be some available that I don't know about) if you want to edit the database from a webpage.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 09-08-2004, 03:05
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
I don't know what your end-all-be-all-goal is... but you can use MS Access.. and do a data access page which allows you to manipulate the database through a web browser...
What do you want to do? Build a database to keep track of renters? There might even be an Access template to do what you want to do!
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 09-08-2004, 07:42
Programming User
Yes, I already have a server setup with MySQL, PHP, and Apache. And they work.
Describing the problem in more detail:
My dad's a real estate agent. I'm creating a website for him and one of the things I pretty much have to have have on it is a list of the houses he's currently selling.
However, I've decided it doesn't matter right now. When I do end up needing this, I'll bring it up again. Thanks to all who discouraged me...
Unread 09-08-2004, 15:27
robot180's Avatar
AKA: Jon
I have an idea then, a photo gallery. However, add in some stuff to store more information about each house and display it below each picture or display a link to a page that displays thew information.
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
What's real, What's better than real... Excelsior12 3D Animation and Competition 26 17-02-2003 20:50
Division assignments now available in Team 340 database archiver 2001 13 24-06-2002 03:05
Playbook now included with Team 340 database archiver 2001 0 24-06-2002 01:33
We have to organize to win archiver 2001 18 24-06-2002 00:00
