Re: Enough buying talk. Let's hear about ghettofab!
Our transmission kept stretching just enough to cause the gears to go past one another instead of engaging. No picture of it, unfortuantely, but we ended up just wrapping it in a gazillion rubberbands...
OK, this is my team's specialty.
Flashback to 2003: 1) We were trying to figure out how to put the numbers on each side of the robot, so one of our software engineers actually took a popcorn tin, cut out a rectangle, and we put the numbers for mailboxes on it. Turns out, it worked quite well, even though it got torn to shreds. You can even see a snowman peeking through the numbers on the plate. 2) I counted, and at one point we had some 500 zip ties on our robot, holding everything together, including the gearbox and the motors. 3) For our stacking mechanism, which was built at the very last minute, we didn't have enough metal to finish the stacker. So we took some wood and cut it for the top of the stacking frame and the lifter. We then spray-painted the wood silver so that teams wouldn't notice that it was made of wood and thus vulnerable. We managed to fool everyone, even up close, into thinking that the wood was aluminum. That, my friends, is ghettofabulous. |
1293 was surprisingly low on ghettofab, due to the fact that we had no duct tape.
I think the biggest ghettofab moment we had was when we couldn't find Mrs. Sutton (our honcho of nearly all things non-robot), who had printed up our team numbers for the robot. We had to have team numbers, so we used the best thing we could think of...electrical tape. And it was like that the entire Palmetto regional. Off of the robot, however, we were kings. We needed a ball tee to practice our autonomous mode, but we didn't have any toilet flanges or anything. Our tee wound up being a lid off of a foam coffee cup (the kind with the indentation in the middle), a length of PVC pipe to fit, and the feeder tray off of a printer to work as a base. (I wound up using tin snips to cut out a perfect fit in the ridges.) It worked for a tee--whether it held up when our robot came stampeding through is another story. |
I have participated in at least two ghettofabs during my 3 years. The first one was 2002.
There was one advisor who insisted on having four, crab-movable and lifting up tank treads, which weighed in at 50 pounds. This only left room for one arm, and we could only haul one goal with all that power. We didn't do well at all that year, and instead of going to nationals (the last time they were held in Orlando ) , we went to the St. Louis Regional. There the other advisors and upperclassmen decided to remove two of the tank treads and replace them with the equivalent of aluminum casters. That gave us weight (about 20 pounds) to put the arm back on and we decided we would have to have a mechanism that goes back to the home zone (to score 10 points). We didn't know what to do until an advisor suggested measuring tape. So we put a roll of measuring tape on the top of the robot and had a FP motor shoot it backwards to the home zone. It worked quite well, and was made completely out of wood, completely on site without any machine shop.This year (2004), our arm wasn't working with the high standards we hoped it would. Even when the pneumatic was pushed all the way in, the ball would still slip out. I suggested supergrip (which we used extensively last year) but it turned out we didn't have any. Then somebody suggested using a popped 2x ball to do the trick. We got a popped 2x ball (I don't remember whether it was form our kit or from our good friends on 447) , cut it into strips, and stretched it around the arms. We then used Zip Ties (Confucius' Law of FIRST: Know thy Ziptie ) to keep it on, and the only times a ball went out of the arm after that was when it was vigorously pushed out. Proof that Ghettofab works. |
zip ties...
We originally had used this nice piece of getofab to hold our wench line up against the arm, and when it was time hang those things would go flying, but by the end of the build we had replace them with some medical tube and hooks which would actually stay intact and on the robot. |
This year 45 had a lot of "ghetto" stuff on it I think. Such as our pool floatie toy pads on the sides and rear. To our front gate we put on at nats that myself and Andy built in like 30 minutes. It was just lexan riveted on to a aluminum tube. It may have been ghetto by my terms but it was also P.I.M.P. HAHA!
-Kyle ![]() |
#7
In the spirit of Dave's comments, I very much believe in the plastic trash can lid also. Our robot this year had an arm with suction. The suction cup: A wal-mart trash can lid with non-porrous foam contact glued to form a seal. To power it: A FP on a shop vac impeller. Other ghettofab parts. Thighmaster roller-pad to supposedly keep from running over the ball. Xerox machine parts used 4, coupler for different motors. To keep the winch from unraveling, a piece of plastic was put around the lead screw. Never came unraveled.
For last year: Edurobot wheels used to form grippers on arm. Held on with plastic automotive push-screws. Caster wheels for turning: We use go kart racing tires on both years robots and can make turning hard. When we had the two extra days we decide to put pneumatically actuated casters on the back to help turning. After plasma cutting a spot while everything is on the robot we fit the caster wheels that saved us from numerous tips into place. Robovation ghettofab: I took the robovation bot to college with me for an open house booth. I realized the tiny tires weren't going to cut it so I saw that I had both foam board and electrical tape. Using the old hubs, foam board and electrical tape I made new wheels which worked great. More foamboard, duct tape, a three ring binder v piece: I build a protective shell with a scoop, side flaps, and a pusher on back with a duct tape hinge. Three ring binder and IFI parts, Gravis gamepad, velcro and 222 battery: Carryable Controls(all fit in the binder). |
#8
125's ghettofabulous moment happened in Annaplois. We used 4 8" pneumatic tires to provide great traction. Unfortunately, we had such traction that turning was almost impossible. To remedy the situation we decided to shave the tread off the wheel.
In the pits we put the robot on blocks and put a student with a file at each wheel. Pretending to drive forward we used the motors power to help shave down each tire. Unfortunately, we had limited success and rubber particles everywhere. You thought the smell of blown motors was bad, the burnt rubber was much worse. Last edited by MikeDubreuil : 11-08-2004 at 05:05. |
#9
We also had a problem with a shaft in our drivetrain gear reduction start binding on us in Atlanta. We had two gears on the shaft that were welded together with a spacer in between them, and we had them cotterpinned to the shaft so that the assembly would ride in bearings. After trying for a couple of hours to readjust the shaft to eliminate the bind, with no success, I had the idea to just remove the cotterpin and let the gears spin on the shaft. This worked very well, despite the fact that we now had steel spinning on steel, but it only had to last for 2 more days so why not go for it? We also got an added bonus by taking out the cotterpins in that our sprockets were now self aligning! As for weight reduction, at Great Lakes last year our robot was about 3 pounds overweight. As a last chance attempt, myself and another team member got out our pocketknives and proceeded to trim the treads off the sides of our tires. It didn't get us 3 pounds, but when you have less than 1 hour left to be inspected for the regional, you'll do just about anything. ![]() |
#10
well, our '02 and '03 bots were entirely ghetto. But last year we had about 3 days to ship, and we had no idea how to attach the flapper (think of a vaccume agitator)(SP and wrong term, but work with me). It was just some rubber strips screwed to a pvc tube. We were using the window motor to power it, we just got PC11, a high strength epoxy and glued to stupid thing on. It worked well for the 2 times we used it.
This year... ELECTRICAL TAPE!!! |
#11
#12
Do you wanna see ghetto fabulous? Our robot was made out of wood, wires were hanging out from every direction and the drive train would always give out. It was so great. The name of our robot was "Robizzle", and the name of our bumpers were "Ghetto Foam". This was our rookie year and I am still proud of our rookie bot!
GO 1403!!! |
#13
Our 2003 rookie year still takes em all.....
http://www.rockwoodroboticsteam1098....t%2003%201.jpg Plexiglass base, and practically everything else wood, with chicken wire protecting our "guts". We also quickly noticed a problem with our drivetrain and controls, since it was chaindrive, and we had a rather simple control system that consited of really only "on or off", so when we would go forward or reverse, the bot would jerk around a lot and almost tip over on several occasions. Our solution? We took a 1/2" piece of sheet metal, bent it into a loop shape, and bolted it onto the bottom of our bot. The result? Never tipped over except once when it ran up and onto another robot, it would constantly be bucking around and made for quite a celebratory dance I distinctly remeber several teams asking us if we had gyroscopes on our bot..... Our 2004 bot was rather "ghetto" as well.... I think the pic is self-explanitory... http://www.rockwoodroboticsteam1098....s/Team1098.JPG However, despite our incredible ghettoness on our 2003 rookie bot, we got 1st in qualifying and if I remeber correctly, got to the semi-finals of the St. Louis regional..... But I attributed that to luck ![]() |
#14
For the 2004 competition, we (1403) created ghetto foam at nationals. Back in the nj regional, we were hit from the side, causing our gearbox to smash. In order to prevent anything like that from happening again, we took foam, cut it into circles, and velcroed it to the wheels. Someone also drew some nice rims with a sharpie.
#15
Team 1640:
Electrical tape and paint team numbers (http://www.team1640.com/gallery/disp...album=5&pos=33) Bumpers made of pipe insulation (http://www.team1640.com/gallery/disp...album=5&pos=35) And last but not least, the WaitGhetto function - it counted to a rediculously high number to act as a timer because we couldn't figure out how to do a proper timer! |
