Go to Post only here would you find someone calling a motor cute.... - Denman [more]
Unread 12-08-2004, 11:46
gomez6760 gomez6760 is offline
gomez6760 has a little shameless behaviour in the past
disabling a button
can someone tell me how to disable or enable a button depending on the name of the button that I have stored in my database but without doing if's in my procedure. What I want is the following:
Example I have 10 buttons in a form. The name of my buttons are stored in my database. But when my database sends back my result (example only 4 names) I cannot put the name of the button because delphi does not know that that is an object, it says that it is a string which is right because you store the name of the button as a string in your database.
I do not want to do a loop an 10 buttons and do if name is equal to btn.name
I would like to do a proedure only with the results
Any suggestions ? Thank you
Unread 12-08-2004, 11:54
Billfred's Avatar
Billfred Billfred is offline
Re: disabling a button
I probably should point you to this sticky. I'm afraid that Chief Delphi is a web site of a FIRST Robotics team sponsored by Delphi, not a site covering Delphi programming.
There are a few folks here who may know Delphi programming, but your odds would probably be better at a Delphi programming forum.
Thanks for stopping by, either way! (Like robots? We've got plenty.)
--Billfred, aka "I am not a moderator, but I am JVN."
(sorry, forum in-joke. couldn't resist)
Button wishlist 2004 natonal's Tytus Gerrish Championship Event 19 16-04-2004 00:53
Button Programing BobcatProgramer Programming 6 25-02-2004 16:43
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
Select button and user mode n[ate]vw Programming 2 20-01-2003 16:33
Just wondering about a button from nats... archiver 2001 1 24-06-2002 04:07
