Go to Post We must remember: if you're reading this comment right now you already "get it." - akeisic [more]
Unread 18-08-2004, 00:49
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Re: My Wall Caught On Fire!---A Classic *Mangia*
So I limited the outlet to one computer and tried my best to reduce strain on the wiring until the problem is dealt with. Furthermore, I wrote a summary of the problem and solution for my father to read. That should prompt him to take action.
ALUMINUM WIRING IS A HAZARD
Background:
On April, 28, 1974, two persons died in a home fire in Hampton Bays, New York. Fire officials determined that the fire was caused by a faulty aluminum wire connection at an outlet.
The Problem:
During the 1970's, aluminum (instead of copper) wiring became quite popular and was extensively used. Since that time, aluminum wiring has been implicated in a number of house fires, and most jurisdictions no longer permit it in new installations. The main problem with aluminum wiring is a phenomenon known as "cold creep". When aluminum wiring warms up, it expands. When it cools down, it contracts. Unlike copper, when aluminum goes through a number of warm/cool cycles it loses a bit of tightness each time. To make the problem worse, aluminum oxidizes, or corrodes when in contact with certain types of metal, so the resistance of the connection goes up. Which causes it to heat up and corrode/oxidize still more. Eventually the wire may start getting very hot, melt the insulation or fixture it's attached to, and possibly even cause a fire due to carbon buildup. Research sponsored by the Consumer Product Safety Commission (CPSC) shows that homes wired with aluminum wire manufactured before 1972 are 55 times more likely to have one or more connections reach "Fire Hazard Conditions" than are homes wired with copper.
The Solution:
Fortunately, there are two options available for dealing with this impending problem. We can have the aluminum wire rewired entirely, the best, permanent, safe solution that is recommended by most professionals. A cheaper alternative would be to have each wire “pigtailed”, which essentially moves the aluminum connection from the receptacle or switch terminal to a more reliable splice. Pigtailing should remove most of the hazard, but is not a 100% guarantee.
My Input:
I’ve had two problems in my room alone with the aluminum wiring already, and twice a small fire has started in our walls, only to be burned out. How much longer can we tempt this hazard? I don’t want to be responsible for any damage, injury, or god forbid death. I told mom about this, but she shrugged it off, accusing me of trying to waste money. If anything happens, it’s all on you and her, because you’ve been warned. I strongly urge you to have this dealt with by a professional immediately, and every person I’ve talked to about the problem through the course of my research has given me that same exact advice. It may be costly to rewire the house, but I’m sure it’s less costly than rebuilding our house from the pile of ashes in the dirt. Insurance may give you some money, but you know as well as I do that it won’t be near enough to cover everything. At this point you have two choices: 1.Shrug this off and wait for an accident, endangering your family and your possessions. 2.Take action and deal with the issue NOW before it becomes a problem. Questions, comments, queries, need a picture of a fire inside a wall? ASK!
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 03-09-2004, 03:27
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Hey Aignam, I was just looking through the Chit-Chat and found this thread. Just wondered how this was coming along. Get it fixed or looked at? if not Then I've got a comment, coming from an electrician ( apprentice with enough hours to really be near master but not enough written down) One major part I can tell you is that having a 20 amp fuse or breaker on a circuit for a bedroom or anything besides your laundry room or kitchen or bathroom receptacles is risk of fire because that wire is normally only good for max 15 amp. Calculating the computer power supplies at 400 watts and drawing 10 amps each is incorrect, the wattage listed is on the secondary, your computers will probably only really draw about 2 amps each if running with the monitor. I did a load test on my system with many other things on the same powerstrip, my amp meter only showed about 2 amp. You could easily run all the items you listed on the circuit and it wouldn't over load it. I run more in my room with no trouble at-all. As everyone else said you MUST get this checked out. It wouldn't take a good electrician much time to rewire this problem. Many electricians will give you a free estimate. You don't necessarily need a "certified" electrician, actually they're called Licensed and thats the only way you can be called an electrician, is if you're licensed, but thats just terminology.
Aluminum wiring is still used today for wiring, It is often used in the main power wires coming into your house. Aluminum does expand and contract but the devices made for use with aluminum wire are designed to compensate and are designed NOT to easily corrode and there is also a DE-OX compound used to prevent corrosion/oxidation.
Pending local codes you could fairly easily rewire the whole room with new boxes, wire and devices (receptacles and switched) for fairly low cost and some little time and effort. Also there is now a device called an Arc-Fault breaker required in many states, if you have breakers installed you can install one of these in place of the breaker feeding your room and if it detects arcing it will shut off before causing trouble.
Didn't mean to be long winded but we fix these problems or problems very similar literally daily.
-Mike
Classic Quote GregTheGreat Chit-Chat 0 12-11-2003 20:37
SCRRF Fall Classic Directions Redhead Jokes Southern California Regional Robotics Forum 0 10-10-2003 17:39
Lost and Found: GHHS Summer Classic June 29 sanddrag Off-Season Events 0 01-08-2002 01:30
Chatsworth Summer Classic Results Amadkow Thanks and/or Congrats 0 25-06-2001 13:35
Chatsworth Summer Classic Results Joe Ross Off-Season Events 0 23-06-2001 23:00
