Go to Post We should have a 'Steps Taken For FIRST' contest. Everyone wear a pedometer and keep a log of how many miles you walked at the St. Louis Championship. That could be a lot of fun. Do they make pedometers for robot carts? - JaneYoung [more]
Unread 01-05-2003, 10:57
Matt Reiland's Avatar
'The' drive behind the drive
Originally posted by Soukup
here's a dumb question, but I don't have a lot of mechanical experience, but how do you guys attach the rollers to the wheel? Is there some sort of special screw or plug hat you use?
Nearly every design I have seen, including ours based on the Wildstang 2001 design, uses two 'half plates' to make up each wheel. In each half plate is milled a 'half slot' that holds the axles of the omni rollers. When the two are bolted together, the omni rollers are captured in the milled out areas of the wheels and the axles are cpatured in the two plates.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 01-05-2003, 12:01
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Pictars...
Since Pictars died I'm not sure if those links still work.
Here are some more pictures.
http://www.chiefdelphi.com/pics/bin/...trickwheel.jpg
http://www.chiefdelphi.com/pics/bin/...46dscf1797.jpg
Purdue Alumni
Cummins, Inc.
Unread 19-08-2004, 08:22
VROGY VROGY is offline
no team (n/a)
VROGY has a little shameless behaviour in the past
Send a message via ICQ to VROGY Send a message via AIM to VROGY Send a message via Yahoo to VROGY
Re: Post your omni wheeled robot pics
very, very cool. you guys use IFI stuff, right?
I wish FIRST would migrate to RC equipment. With the advent of cool stuff like synthesized frequency modulators, all you have to do is 'dial-in' your frequency... and at that point, it's stil cheaper than the IFI systems. meh, YMMV
another great thing about that is that you can use cool stuff like this.
Unread 19-08-2004, 22:38
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Here are some pictures of some of the stuff I worked on while on Cornell's Robocup Team:
Exploded view of wheel
Engineering Drawing
Engineering Drawing of Lexan Hub
Engineering Drawing of Roller (small rollers around the wheel)
CAD View of Robot w/ Wheels
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 21-08-2004, 00:53
white_ChocOlat8's Avatar
white_ChocOlat8 white_ChocOlat8 is offline
AKA: white chocolate
FRC #1902 (Team EMOTICONS)
Team Role: Marketing
white_ChocOlat8 can only hope to improve
Send a message via AIM to white_ChocOlat8
this is what 1083 used this year. http://www.chiefdelphi.com/forums/pi...gle&picid=6118
EXPLODING BACON!
OINK OINK BOOM
Unread 22-08-2004, 15:54
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
though most people use two plates with milled slots, we use three plates. the middle plate in our case was waterjetted with slots to hole .125" steel pin upon which the delrin wheels could spin. this technique saved used tons of time, but i realize not everyone has a waterjet.
another interesting approach was a spherical wheeled kiwi drive that we prototyped extensively but never used. trust me, it's awesome.
kiwi wheel
kiwi drive
spheres
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 22-08-2004, 22:07
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
OMNI WHEELS! from 1126 on 2003 robot, Mighty Pneumatic Nightmare
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 03-10-2004, 10:38
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
We just got some omni wheels and put them on our robot last week and we are currently testing them in replacement of two casters on the back of our robot, i don't have a picture yet but i can get one later this week. This is the first time my team has experimented with omni wheels and if everything works out we might use omni wheels on our 2005 robot if needed.
Unread 03-10-2004, 12:53
Blacknight's Avatar
Blacknight Blacknight is offline
Duct Tape King
#0180 (S.P.A.M.)
Team Role: Driver
Blacknight will become famous soon enoughBlacknight will become famous soon enough
S.P.A.M. Used Omni last year
wheel
If anyone has problems with code we have pretty much mastered omni (except for autonomous) Our software team was going to write it up in a white paper but they havn't gotten around to it.
(\/)/\++ |)0\/\/|\|§
sn-TheGreatestKahn
Are there indelible lines that divide sanity from insanity, or do the overcross at the slightest change in the world...
Unread 02-12-2004, 20:25
Bcahn836's Avatar
Iraq is fun.
AKA: Brad Cahn
Here is a picture of the omni wheels we used on our 2004 robot.
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 30-03-2003 23:00
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 10-02-2003 00:25
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 12-01-2003 22:19
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 05-01-2003 22:04
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
