Dead RCX..
Unfortunattely, all of a sudden, my RCX 2.0, stopped functioning.
It doesent even goes on and off. The batteries are new. I've tried to unlocking it by removing the batteries and holding the on/off button until I hear a beep as lego mentions, but nothing happens, no beep for me. I would like to ask if there is a way to unlock the RCX. I already opened it and it seems nothing's wrong inside.. Please help.. ![]() |
Re: Dead RCX..
Other than that, I'd say you're screwed. Did you connect something to it that fried it? Very rarely these things happen out-of-the-blue; they're usually provoked. |
Re: Dead RCX..
This happened to me recently.
I pulled the batteries out, let it sit a few days, put the batteries back in, and it was fine. ![]() Hope you get it fixed. |
Re: Dead RCX..
anybody have problems with RCXs that don't respond to IR, but still turn on? i have 3 of those currently in my posession.
![]() anyway, try to contact lego about it. they never responded to me, but maybe you will have better luck. |
Re: Dead RCX..
![]() Oh, yeah. Do they respond to the LEGO remote control? Just out of curiousity. |
Re: Dead RCX..
Re: Dead RCX..
while i have no idea why you guys' rcxs dont work, i have a problem of my own.
my ir tower isnt working.. or maybe sumthing else. whats wrong, is that when i try to download a program tothe rcx, i cant. well. i could, but only if the program is REALLY short. like at max i got to dl was 5 blocks. (im using rcxc1.5) 5 blocks of the normal green ones. no "if" blocks. i have no idea why it dls small programs but not large ones. it used to work on my old computer, but with this new laptop im using, it just isnt working. any ideas? anyone? help? oh, and it isnt the rcx. i have two 1.5s and one 1.0 with the same results. |
#8
Re: Dead RCX..
#9
Re: Dead RCX..
The batteries are new.The polarity is correct. I 've never load anything in the RCX, it was brand new, I only turned it on and off a few times and then when I tried to put it in a contstruction I've made, I pushded downwards, then I've heard a long beep, and it never went on again!... I've already checked the internals..Everything looks fine in there.. I 've never connected anything to my rcx.. It seems that is locked someway.. I've removed the batteries for 24 hours, put them back, but still no operation.. There is no fuse inside the circuit.. I was wondering if there is an unofficial way, by shortcircuiting something e.g. or by applying external power to the board, to rivive it.. It is very odd, but the RCX stopped functioning out of the blue.. I've also tried to hold on pressed the on/off button while removing the batteries, it supposed to hear a beep and unlock the RCX as a troubleshooting guide of lego said, but nothing happened..no beep, nothing at all.. ![]() |
#10
Re: Dead RCX..
Check lugnet, but by the sound of it I think you should call lego and ask for a replacement.
Don't worry; they're generally pretty good about that kind of thing. |
#11
Re: Dead RCX..
I've already done that, they told me that in 1 or 2 weeks time they will send me a new rcx, but I was wondering if there's a way to put back in life the old one. If one rcx is ok, then i suppose two of them are great! ![]() |
#12
Re: Dead RCX..
its the com tower but im using a usb to serial adapter because my laptop doestn have any serials. the tower is using a brand new 9v battery. how do i check the cable? the computer port(the usb one) works great with everything else ive used it for, like thumbdrives |
#13
Re: Dead RCX..
The best way to check the cable is to connect it to 2 computers and open HyperTerminal.
#14
Re: Dead RCX..
I think you'll need to get a computer with a serial port to download. The USB and COM towers work differently, specifically the COM tower shuts down and has to be woken up again, where as the USB stays on the entire time it is plugged in. If you configured the LEGO software to work with the USB tower, then that's your problem. (I think) |
#15
Re: Dead RCX..
i havent configured the lego software, i dont think,. is there a way to? |
| RCX Programming | Guyute | FIRST Lego League | 10 | 23-08-2004 16:25 |
| Using an FRC with the RCX? | Astronouth7303 | Programming | 21 | 15-04-2004 14:14 |
| What to do with autonomous | Rickertsen2 | Programming | 48 | 17-02-2004 16:22 |
| Controlling a FIRST robot with a Lego RCX Controller? | archiver | 2001 | 5 | 24-06-2002 04:19 |
| dead robot in the finals? | srawls | Rules/Strategy | 2 | 24-03-2002 14:44 |
