Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Go Back   Chief Delphi > Other > FIRST Lego League > Lego Mindstorm Discussion
Unread 23-08-2004, 20:07
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Dead RCX..
This happened to me recently.
I pulled the batteries out, let it sit a few days, put the batteries back in, and it was fine.
Hope you get it fixed.
Unread 23-08-2004, 20:15
Mike Ciance Mike Ciance is offline
FRC #0025 (Raider Robotix)
Mike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant futureMike Ciance has a brilliant future
Send a message via AIM to Mike Ciance
Re: Dead RCX..
anybody have problems with RCXs that don't respond to IR, but still turn on? i have 3 of those currently in my posession.
anyway, try to contact lego about it. they never responded to me, but maybe you will have better luck.
Unread 23-08-2004, 20:19
Programming User
Re: Dead RCX..
I assume you've tried the obvious stuff, like pull the batteries out (let it sit for a while before putting them back in), done it in a pitch black room, etc. Gee, wish I had that many.
Oh, yeah. Do they respond to the LEGO remote control? Just out of curiousity.
Unread 23-08-2004, 20:30
Re: Dead RCX..
they don't respond to any kind of IR, including the remote. i have not tried it in a pitch black room, but other RCXs work in the same setting, and one RCX used to and then stopped. i could understand if we dropped one and it stopped working or something, but all 3 have the same problem - just the IR. i dont get it.
Unread 23-08-2004, 23:15
occra 23.
AKA: ryo
None #1481
Re: Dead RCX..
while i have no idea why you guys' rcxs dont work, i have a problem of my own.
my ir tower isnt working.. or maybe sumthing else.
whats wrong, is that when i try to download a program tothe rcx, i cant. well. i could, but only if the program is REALLY short. like at max i got to dl was 5 blocks. (im using rcxc1.5) 5 blocks of the normal green ones. no "if" blocks.
i have no idea why it dls small programs but not large ones. it used to work on my old computer, but with this new laptop im using, it just isnt working.
any ideas? anyone? help?
oh, and it isnt the rcx. i have two 1.5s and one 1.0 with the same results.
Unread 24-08-2004, 14:22
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Dead RCX..
  • Check the enviroment; I believe this solves most problems
  • Is this the COM or USB tower? the COM tower requires a 9-volt battery
  • (COM) Is the cable good? It's a null-modem cable, so check it.
  • Is the computer port OK?
And has anyone tried LUGNET yet? The group you probably want is lugnet.robotics.rcx.
Unread 24-08-2004, 20:21
occra 23.
AKA: ryo
None #1481
Re: Dead RCX..
no, ive tried in a dark room, and also with making kinda like a tunnel between the tower and the rcx with white paper. same results...
its the com tower but im using a usb to serial adapter because my laptop doestn have any serials. the tower is using a brand new 9v battery. how do i check the cable?
the computer port(the usb one) works great with everything else ive used it for, like thumbdrives
Unread 24-08-2004, 20:24
AKA: Jamie Bliss
Re: Dead RCX..
The best way to check the cable is to connect it to 2 computers and open HyperTerminal.
Unread 25-08-2004, 07:17
Programming User
Re: Dead RCX..
Well, we all know how well USB-serial converters worked for the FRC/Edubot controllers.
I think you'll need to get a computer with a serial port to download. The USB and COM towers work differently, specifically the COM tower shuts down and has to be woken up again, where as the USB stays on the entire time it is plugged in. If you configured the LEGO software to work with the USB tower, then that's your problem. (I think)
Unread 25-08-2004, 09:10
occra 23.
AKA: ryo
None #1481
Re: Dead RCX..
we do? i dont... but im guessing they didnt work too well?
hmm. the only thing is, that it works with the small programs.. if it didnt work at all, itll be somewhat more explainable.
i havent configured the lego software, i dont think,. is there a way to?
Unread 25-08-2004, 09:21
Programming User
Re: Dead RCX..
The small program thing actually makes sense though. The COM tower will just shutdown if it isn't kept alive (I thought that the mere act of sending data to it would do that, but maybe not.), so after the first 5 seconds of transfer, it gets turned off. If it's a small program, it gets sent in that time. Otherwise, it gets interrupted and the RCX erases what it did have, because there's no point in keeping the incomplete program.
Unread 25-08-2004, 09:35
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Dead RCX..
I just talked to greencactus3 on AIM.
It seems also to me that there is a problem not being switched to Serial Tower.
He did clear out the RCX of all programs using the Reformat thing.
If it takes little programs there can't be a problem with the USB to Serial converter or not being on the right COM port
I do not have the software in front of me could someone tell him how to switch to Serial using RIS 1.5??
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 25-08-2004, 14:39
AKA: Jamie Bliss
Re: Dead RCX..
The serial tower stays on for 3 seconds after the last transmit, during which it can recieve messages. It is woken up when you send data. There is a hack to make it stay on when the RTS pin is on.
In RIS 2, it's in the options screen, or when you install the software. If it isn't there and the help file won't tell you, it might not support USB (Though the drivers for the COM/USB thing should set up a virtual COM port).
Try using CommTest from my site. (http://endeavour.zapto.org/astro73/programs/) The current version has some bugs, I'll tell you in it's fixed.
Send anything out the COM ports (try each one) and look for the green light.
Unread 25-08-2004, 15:11
Programming User
Re: Dead RCX..
Isn't RIS 1.5 always set to use the serial? It doesn't support USB as far as I know.
Unread 31-05-2005, 00:48
robbie thompson robbie thompson is offline
robbie thompson is an unknown quantity at this point
Re: Dead RCX..
hey mike i have the same problem....i too have emailed LEGO and they havent replied ,,,just wondering if you have had any luck recently
RCX Programming Guyute FIRST Lego League 10 23-08-2004 16:25
Using an FRC with the RCX? Astronouth7303 Programming 21 15-04-2004 14:14
What to do with autonomous Rickertsen2 Programming 48 17-02-2004 16:22
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
dead robot in the finals? srawls Rules/Strategy 2 24-03-2002 14:44
