Go to Post Every robot needs a locky-thingy. A robot without one might fire when it isn't supposed to, and hit the wrong target; e.g., a referee, FTA, or robot inspector. - Richard Wallace [more]
Unread 24-08-2004, 23:00
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: lathes, what's best?
Originally Posted by Stu Bloom
Dave, I don't doubt your figures ... but how in the heck to you support a piece of stock between 80 foot centers ??
When the piece of stock is 12 feet in diameter, it is not too much of a problem!
(but it is not really just a solid piece of stock - it is actually the outer skin walls of the first stage of the rocket, which is made of three isopanels, bent to shape and welded together into a cylinder; the whole assembly is then turned on the lathe to true it up as the tank end caps are welded on).
I have a picture of this bad boy somewhere. I will post it if I can find it. But in the mean time, take a look at this big Bridgeford lathe being used to turn a 20-foot auger bit.
-dave
Unread 25-08-2004, 00:49
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Is this it?
-Kevin
Kevin Watson
http://kevin.org
cnc/cad/cam help chbix Technical Discussion 12 07-07-2004 22:40
Grizzly Lathe Opinons Caroline General Forum 7 28-08-2002 18:55
Sub Contracted, Eh? archiver 2000 24 23-06-2002 22:28
