#16
Re: How Many SETI Data Units Have You Completed?
--EDIT-- Also, know of any more fun BOINC distributed computing things I could join? ![]() Last edited by Ryan M. : 25-08-2004 at 15:09. |
#17
http://www.chiefdelphi.com/forums/sh...highlight=seti |
#18
Cory |
#20
Yea, you can process without an internet connection... but when it finishes doing how ever many packets you have it download... it needs to connect to upload the results and download the new packets. But during the actual processing you don't need a connection.
As Elgin pointed out earlier... there are several FIRST groups. I never knew about those myself, I'll join up with one of those... but I think we should all make an agreement as to which group to join so we're all together. I'd suggest http://setiathome.ssl.berkeley.edu/s...am_163242.html since 2 of the other 3 have nobody, and the 4th only had 1 user. Edit: I noticed that group has all inactive members. What do you guys think would be the best idea? Just join up with that one... or another, or what? I guess it doesn't really matter if we all reach an agreement so we're together ![]() Last edited by miketwalker : 25-08-2004 at 19:45. |
#22
I don't beleive seti by itself can cache units, so you need to be
online, at least to download work (then it will do that unit and wait for you to connect again). However, there are programs that will cache work units for you. One of those is Seti Driver, and you can read about it here: http://www.teamlambchop.com/tips/setidriver.htm I'm not sure if you can use that or anything else to sneakernet workunits, though. Code:
Your credit: Name (and URL) sciencewhiz Results Received 50 Total CPU Time 196 hr 54 min Average CPU Time per work unit 3 hr 56 min 17.7 sec Average results received per day 0.08 Last result returned: Tue Feb 3 05:38:19 2004 UTC Registered on: Sat Dec 21 04:06:14 2002 UTC View Registration Class SETI@home user for: 1.681 years Your group info: You belong to the group named: TeAm AnandTech You are not currently the founder of any teams. Your rank: (based on current workunits received) Your rank out of 5106790 total users is: 1249782nd place. The number of users who have this rank: 9732 You have completed more work units than 75.337% of our users. |
#23
OMG.. 19.5 hours for my first packet..
Whoop dee doo... |
#25
Wow, now that I actually got rid of the BOINC, and installed something that works. I left it running all night on my zd7000 I don't think I'll do that again. HOT! HOT! HOT!
I'll have to let it run when I'm at classes for short periods of times or something, I'm suprised my case didn't start to melt. |
#26
BONIC suppose to be a improved version of SETI Classic, from my point of view it's unreliable. One day downloading data, other day showing no work available for 24 hours. I definitely like the classic better. |
#27
I would have made a FIRST Group awhile back, but I got stuck in some other group. I put an HTML tag in the header that it didn't like, just as a test, and now the page I need to get to in order to quit the team doesn't load right because of that one tag. ::hmph:: |
#28
I'm not sure why, but I am finding this fun on some level. Checking back every so often and just seeing "Ooo, It finished another 3.79%. But then again, maybe I'm just wierd.
Your credit: Name (and URL) Jbomb3 Results Received 24 Total CPU Time 63 hr 11 min Average CPU Time per work unit 2 hr 37 min 58.9 sec Average results received per day 3.46 Last result returned: Thu Aug 26 12:45:32 2004 UTC Registered on: Thu Aug 19 15:05:25 2004 UTC View Registration Class SETI@home user for: 166 hr 32 min Your group info: You do not currently belong to a group. You are not currently the founder of any teams. Your rank: (based on current workunits received) Your rank out of 5107459 total users is: 1608977th place. The number of users who have this rank: 21525 You have completed more work units than 68.076% of our users. |
#29
One unit completed
Fourteen Hours, 42 minutes, 35.6 seconds. :-D |
#30
My average work time:
4 hr 04 min 21.5 sec (over 4 units) See the rest of my stats at: http://setiathome2.ssl.berkeley.edu/...user_stats_new |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Competition Scouting | pauluffel | Scouting | 31 | 09-01-2003 00:34 |
| Robot Scouting Database | archiver | 2001 | 10 | 24-06-2002 03:00 |
| Limiting PWM in pbasic | archiver | 2001 | 4 | 24-06-2002 00:38 |
