Go to Post I know I know, resurrecting an old thread, but at least I searched! - Beth Sweet [more]
Unread 25-08-2004, 21:46
white_ChocOlat8's Avatar
white_ChocOlat8 white_ChocOlat8 is offline
AKA: white chocolate
FRC #1902 (Team EMOTICONS)
Team Role: Marketing
white_ChocOlat8 can only hope to improve
Send a message via AIM to white_ChocOlat8
the application failed to initialize properly (0xc0000033)
"the application failed to initialize properly (0xc0000033)"
when i loaded inventor on to my computer and i tryed to open it it gave me that message, and i was just wondering how do you go about fixing this. My OS is win. XP if it makes a difference.
EXPLODING BACON!
OINK OINK BOOM
Unread 25-08-2004, 21:50
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: the application failed to initialize properly (0xc0000033)
What service pack? i believe the hex is an address. Does a reboot or full boot help? And yes, it does make a difference.
EDIT: Oddly enough, MSDN/KB, Google, nor the autodesk site seem to be helpful. try the Inventor Discussion Group.
Unread 25-08-2004, 22:03
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
What version of Inventor? I have seen errors like this from Inventor 5, when it was not installed correctly. Also, I have seen this exact error on systems where Inventor 6 was installed and users tried to start Inventor 5 (the two were installed in different directories).
Inventor is a massive program and tends to present errors if it is not installed correctly. If you try and force it to install it as a normal user, it tends to go south. I would try reinstalling it first. Then if that doesnt work, i'd install the latest Service Pack for the Operating System, or reinstall it if the system is at its highest level.
Also, try quitting any large running programs... Inventor hearts RAM.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 25-08-2004, 22:10
I am using version 7. but now when i try to open a program like paint its giving me the same response. could it possibly be something fixed by a reinstalling of windows?
EXPLODING BACON!
OINK OINK BOOM
Unread 25-08-2004, 22:32
FRC #0030
If even Paint is giving such errors, I'd first try System Restore. If that doesn't work, reinstall Windows.
Have you installed any unusual programs recently, or changed anything major in your system? They might be the root of the Windows errors. Also, try closing any unnecessary processes from the Task Manager. I like to keep the number of running processes when I am not running anything under 20. The more simultaneous programs, the greater the chance for an unwanted interaction.
Team 30, 2002-2005
Unread 25-08-2004, 22:40
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
You didn't happen to run Windows Update today did you? After installing the latest IE security patch, my FTP server randomly stopped working and gave me a similar error to the one you're getting now. Just a thought....
