Go to Post As I told my friend Joe Johnson, just because you aren't around as much doesn't mean that you can just close the book on this chapter, instead - just keep a book marker in this place, so you can remember how to find your way back home - when the time is right. - meaubry [more]
Unread 26-08-2004, 12:25
Matt Reiland's Avatar
'The' drive behind the drive
Re: Batch Plot
Not totally sure of your question. You have 113 different .DWG files and you want to print them all out? For this I would use PlotIt which is a major enhancement to the Built In AutoCAD batchplot utility. If you are trying to do something else maybe you could explain it again.
http://www.m-c-2.com/main.htm
Also at work here, we have a directory set up and a computer that looks for .DWG files in a set directory. Anything you drop in there will automatically get plotted out.
Matt
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 26-08-2004, 12:34
shoman24v shoman24v is offline
shoman24v is an unknown quantity at this point
Re: Batch Plot
Well what we have is 11 different DWGs. Each street is about 2-4 miles, and every page is seperated by a match line, we have mulitple viewports each including a title block and page number. What i want to be able to do is somehow drag (well say file number 2 out of 11) and print the 8 pages in the viewport connected to it without actually selecting each page in the layout view
I have a feeling that this is not possible...ill probably have to make a plot file of every viewport and then plot it....?
Unread 28-08-2004, 00:05
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Batch Plot
What version of AutoCAD?
As for an immediate solution.. Hire a temp for a week. That's what I did mostly when I worked as a drafter at my last job. We had print requests come in from everywhere and I had to plot them all. I think the largest job I had to do was about 70 C and D size prints. That was a 2 week job, (timed that way for sanity's sake) and the plotter was constantly being used those two weeks by myself and the other drafters in the department.
Another thing you have to think about is the amount of paper and ink you will be using to do this.. Is it really worth it in the end? (I'm assuming yes.)
That's a lot of paper rolls. And you said D size?? I hope Fresno has a paper mill nearby to buy out the entire warehouse's stock.
The IRI Plot Grows Thicker... Amanda Morrison Off-Season Events 3 01-07-2004 21:07
Stamp Plot Lite Adrian Wong Programming 4 15-01-2002 00:08
