Go to Post I hope that kids will stop asking us if we build Battlebots and start asking us if we build Transformers. To that, I will answer with a resounding yes. - Madison [more]
Unread 26-08-2004, 22:17
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox
Originally Posted by Tristan Lall
You're welding some of the gears, I see. I'm not a fan of welding, because it can make disassembly a great pain. I'd recommend keyways if possible. (Consider adapting the design for keyways; despite the initial difficulty of putting them in, if you lack a broach, they're very precise and easy to work with.) If you do weld, make sure that the materials are compatible!
Also, the key way option lets the gears stay intact in a high stress situation. In situations like that, the gears teeth will break faster than the weld will, so if you have a couple spare boxes laying around, I would weld them, but keying is much more reliable and easier to change in a breaking situation.
That is one reason we don't weld gears onto shafts anymore.
White Paper Discuss: Continuing the Cycle: A Guide to Starting a University-Supported FIRST Team CD47-Bot Extra Discussion 2 15-05-2006 14:58
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
White Paper Discuss: Team 159 3.0 CD47-Bot Extra Discussion 2 24-06-2003 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
