Go to Post We are in the business of teaching our students. One of those things should be respect for the rules... - Tuba4 [more]
Unread 30-08-2004, 10:20
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Re: White Paper Discuss: Team 179 conceptual - single speed - 3 motor gearbox
Welded gears - you're pointing out that the key will shear before the teeth come off? I'd like to go with keys, and I don't want to warp the shafts - but back to the intent of this design as cheap and quick, and can it last a few months - maybe not. I haven't checked out that loctite #609 Andy mentions yet. That sounds pretty cool if there's a bond that can take those torques without a key- wow.
Anyhow, this is still more of a risky design, that I want to test to see if like Andy says, will it get me through 4 competitions, not will it run for 6 years. "Cheap and Cheerful" as my colleague puts it.
no 32 pitch on the .7 plastic gear, yah I agree - I think I'm just going to use this as a 2 motor design, as it's original intent. But I might towards the end of it's life throw the FP on there just to see what happens. The nice thing was that to accomodate the FP all I had to do was put a hole in the sideplate.
Shaft output, yah - we used this method off the plastic gearboxes the last 2 seasons just coupling straight out to another bridged/bearing shaft. It wasn't pretty but what we did was shim the motor mounts to the transmission wherever it wound up. But if the design permits I might throw a sprocket right on that output shaft instead of a coupling. The problem with this motor configuration is that you don't have a clear access side since motors protrude from both sides. I like the look of the new Andymarkbiz setup - with both on the same side.
1/8 side plates should be ok since I've got them sandwiched with 6 spacers over a small area. 1/8 plate is tough stuff. Unless we do put the sprocket right on the output shaft, then she'll see some much more significant loads.
I know my views on all this make conservative folk cringe but I think if it works it's all worth it- Come on you gotta admit it
Thankyou guys for your input, it's all very helpfull. I'll be sharing it with the build team.
www.179swampthing.org
Unread 30-08-2004, 12:49
Swampdude's Avatar
AKA: Dan Quiggle
Good so the stock carbon steel 24 pitch gears work :-)
I think I'm going to switch the bearings to the Sintered Bronze, Oilite flange bearings on Small parts - those things are $1.50 ea.
also going to look into the #609 loctite for gear bonding vs. welds
Now we're talking!
Unread 30-08-2004, 21:57
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Now we're talking!
I strongly recomend staying with roller bearings. I have seen may teams learn this lesson.
The way I look at it, we are all limited by the amount of energy we can put into our motors. A design that has less parasitic losses will put more of that energy to the ground.
Matt"s
$0.02
White Paper Discuss: Continuing the Cycle: A Guide to Starting a University-Supported FIRST Team CD47-Bot Extra Discussion 2 15-05-2006 14:58
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
White Paper Discuss: Team 159 3.0 CD47-Bot Extra Discussion 2 24-06-2003 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
