Re: Coolest Drive Train
Inorder for that to work you have to dig into the ground. First off the carpet we use id pretty stiff - and you won't sink in much - and 2nd is when you get in a pushing match - can it push? That is totaly apart of the game and o honestly don't see this drivetrain even being any help to the FIRST playing field...(unless it's done on dirt/water/etc...)
You could run rollers along the threading-- omni-wheelish like.
Another problem i see is with these drves are always set wider then the body. that will really eat up alot of your 30''X36'' footprint causeing some serious space problems. and makeing those HDPE would be possible at only with a 2'' round bad only costing 7.43 a foot
#7
#8
sure these will be cool, but on carpet? i dont think they'll be too practical. and just as tytus says, mecanum will work, but whats the point then..? just make a basic skidsteer tread and itll be much more compact and reasonable.
#10
I had thought of this same drive train before, the only major issue I had was how to do a speedy turn, you could lock one side up and power the other, but you cannot apply foward to one, and reverse to the other, you would slip sideways. But if you did make theise with deep threads around .5 and pretty thin like 1/8" I think you would get enough penetration into the carpet to get some nice traction. hrmmm... (starts stareing at his box of old printer parts and wondering.)
| White Paper Discuss: Drive Train Basics | CD47-Bot | Extra Discussion | 6 | 06-09-2012 11:42 |
| pic: 6 wheel drive train pick | CD47-Bot | Robot Showcase | 3 | 14-04-2004 07:10 |
| what's your most important drive train advice? | Ken Leung | Technical Discussion | 42 | 07-01-2003 09:58 |
| Another chapter in the drive train story | AdamT | Technical Discussion | 19 | 29-09-2002 13:52 |
| Blowing fuses/tuning drive train | DougHogg | Motors | 10 | 23-06-2002 00:24 |
