Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 03-09-2004, 23:57
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
2004 control board emulator
im not sure where to put this but i was wondering if anyone knows of a 2004 control board emulator. im learning to program and i want to be able to test code without breaking anything.
Unread 04-09-2004, 00:31
Umm Errr...
Re: 2004 control board emulator
The simple answer is there is no easy or even remotely easy way for a beginner to simulate code. There is a emulator for PIC Processors but signifigant portions of the default code would have to be rewritten just to make it compatible with the emulator.
My advice to you would be to mess around with whatever you want and don't be afraid of "breaking" anything. There is no way to "break" the controller or any other part of the control system through code (unless you accidentally program your robot ro drive off a cliff or cause some physical damage).
1139 Alumni
Unread 04-09-2004, 00:59
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
If you are just trying to test your own basic "main loop" code (no interrupts or other stuff that needs processor specific emulation) you can just write a simple wrapper for your code that allows for some method of input on a PC and then use a conventional debugger to look at your program. If you don't know how to use a debugger, do it the old fashioned way, just output your data at key points in the program
Team 1257
Unread 04-09-2004, 08:47
CmptrGk's Avatar
Programming Mentor
AKA: Dillon
ok so i will just try the code out when i finish.
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 04-09-2004, 16:13
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I would recomend using the board with servos attached to the PWMs. (They make cool speedometers!) If you really need to use the PC (ie, you don't have access to an RC or EDU), i'd say sorry. It just doesn't work well.
White Paper Discuss: 2004 Visual Basic 6 Dashboard Control CD47-Bot Extra Discussion 2 01-02-2005 01:56
White Paper Discuss: 2004 .NET dashboard control dll CD47-Bot Extra Discussion 7 13-01-2005 17:32
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
frying control board Denman Technical Discussion 7 07-07-2004 19:11
Designs for control board? batbotcrewfrosh General Forum 6 05-02-2004 00:00
