Go to Post How about "Lebron"? Wait, no, you'll be dooming yourselves to failure the last 30 seconds of every match. - Travis Hoffman [more]
Unread 05-09-2004, 00:13
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Re: Calculating Wheel Size
I actually think that if you'd look at it, many of the more sucessfull teams have used smaller wheels on their robots. With a larger or wider wheel you sacrifice manuverability. Also when you start getting into some very large wheels, you'll have much more of a tipping issue. The robots I've seen that used wheels almost wheelchair sized all seemed to not be able to stand upright. You could probably help to compensate for this if you mounted the wheels high on the robot, but then that complicates your design.
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
Quatro 4 wheel drive ufa_mike Control System 2 15-04-2004 02:30
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
