Go to Post Wow I am old. How did that happen? - Paul Copioli [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 10-09-2004, 23:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
How long can car idle on a tank of gas?
With all the talk about the hurricanes and seeing that stores are out of generators, it got me wondering if you could just use your car with a power inverter. Of course a ton of batteries would be the optimal choice but most people don't even have any or many. Even I have only about 50 Ah of SLA batteries lying around and half arent even charged. SO, say you use your car to power an inverter. So all the time it is just idling with the load of the alternator. I know it depends on the car and engine and size of gas tank but can anyone give me an idea of how long it would last. Or at least how much gas per time the car consumes while idling? Thanks.
Unread 11-09-2004, 02:48
Billfred's Avatar
Billfred Billfred is offline
Re: How long can car idle on a tank of gas?
This is by no means an educated guess, but I'd imagine that you'd be good for a bare minimum of four hours, especially if your car's engine is still good. You'd probably have to juice the throttle now and then to keep the engine happy, but other than that I think you'd be alright.
DISCLAIMER: I don't know that for sure. Use at your own risk. We reserve the right to make substitutions or edits without notice.
Unread 11-09-2004, 03:32
REVving up for a new season
FRC #2848 (All-sparks)
this really depends on a few things...1 how large in watts is your inverter. i say this because your amperage off of the alternator varies with engine rpm. so to get a higher RPM you will need to apply more gas thus shortening your run time.
so for a small inverter like 50 watts, it can probably run on just the idle but if you get a larger one like 1200 watts you will need to open the throttle up more to keep the power flowing.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 11-09-2004, 20:16
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
I actually did this when we had a power outage for almost a day. I wasn't sure what was going on so I needed a way to run the TV for awhile. I used a 150W power inverter I have and used my '97 Toyota Camry (4 cylinder) to run the inverter. I only used it for about 1 1/2 hours but I let the car just idle out in the driveway and ran an extension cord back into the house. I don't know the wattage of the tv off hand but it was a 13" I have in the kitchen. As long as the engine is in good shape, the fluids aren't low, and the front of the car isn't obstructed (like having it nosed into a shrub or something else that would decrease airflow) no damage should be done to the car or engine.
As for how long I don't have an exact answer but the gas gauge on my 4 cyl Camry didn't even move. I would guess that the car would run almost a full day on a full tank (18 gallons). If I had to run it all day I would still shut it off every few hours to give it a rest.
P.S. Too bad that inverter couldn't run the 'fridge. We had to throw most of the food away..........after we had gone shopping the day before. Of course the alternator couldn't handle that kind of a draw either.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 11-09-2004, 22:03
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Well...
I'd say minimum would be 3-days on my Jeep. (Inline-6 4.0, 90 amp alt at 14 volts)
Think how much energy is needed for your vehicle to travel one mile - and on a tank of gas I can get about 300 miles.
I wouldn't worry about it...(just don't draw too much power...)
That rug really tied the room together...
Unread 12-09-2004, 01:28
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Probably for quite a long time, for the reasons pointed out above. Try this for some peripherally related information on inverters (from 12 V DC batteries).
But just as a public service announcement, avoid carbon monoxide poisioning, no matter how comfortable your car's seats are. Don't do something you won't live to regret.
Unread 12-09-2004, 13:12
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
yesterday i tailgated the UCF football game and we were using my car stereo as a bom box. 800 watts (max) pulling for 6 hours with the car idling. I have a 3.3L V6 thats in great shape. Even in the hot central florida sun the temperature gague stayed right where it is supposed to be. I proabaly used 2 gallons of gas, if that much. My car has a 110amp alternator.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 12-09-2004, 20:59
AKA: Maher Attallah
[off topic]
Andrew - it isn't a Intrepid is it? Or a Caravan?
[/off topic]
And about your 800 wats max - that is when It hits at max volume. I bet you where running at about 1/5 power and when it hit at about 1/2 to 3/4 power.
Even at that rate - you where still pushing 160 watts (and that's a loud system - so I bet even less at 'normal' volume)
Unread 12-09-2004, 23:04
Git 'em!
Originally Posted by Matt Attallah
[off topic]
[/off topic]
Close Guess with the Caravan. its a nissan quest. And i had the volume all the way up, we had to be loud enough so we could hear it over the crappy music playing a few spots away. All of my speakers are rated for much more watts than I'm capable of pushing through them.
Robot in 3 Days
Unread 12-09-2004, 23:43
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
[off topic]
[/off topic]
Matt this is way off topic but i love that movie FEAR AND LOATHING IN LAS VEGAS, lol infact i am watching it right now with my roomate
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 13-09-2004, 00:42
Elgin Clock's Avatar
Was that an add-on by you? Don't most cars come with a 90amp alternator?
I thought the only cars that had higher one's were VW's for some reason or another.
Unread 13-09-2004, 12:46
AKA: Maher Attallah
I'd agree on most V-6's but normally too you can get a better alternator just by asking. All of our chevys here (the 2.2 I-4 all the way up to the 6.0 V-8s have 2 alternators. Just one for the 'base' model and the heavier duty one for the 'limited' models.)
And standard on the Chrysler 5.2 is a 120 amp and on the 5.9 I think it's 160 amp.
[/offtopic]
Car Bashing Fundraiser? Billfred Fundraising 22 14-06-2004 16:20
What is Car Nack's Corner? Joe Johnson Car Nack's Corner 1 09-01-2004 21:44
How long should production time be??? archiver 1999 4 23-06-2002 23:16
