Go to Post Inaccurate data is not data. It's guessing. - George1902 [more]
Unread 14-09-2004, 02:10
superbeano2004's Avatar
superbeano2004 superbeano2004 is offline
CAD Mentor
AKA: Gerald Bailes
superbeano2004 is on a distinguished road
Send a message via AIM to superbeano2004
Exclamation Help with drive train
I am a mentor from Team 1422 and last year was our rookie year. We had MAJOR problems with our drive train and this year, we hope to fix it so we aren't stranded in the middle of the field. Sigh...so, I'm asking teams for advice on what we can do to help our little dilemma. I appreciate ANY suggestions or advice. Thanks everyone!
Unread 14-09-2004, 02:16
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: Help with drive train
Does that mean you are trying to find ways to fix the old style of drivetrain or are you looking for a completely new design. If you want to modify the old design, it would help to know what the old system was.
Eric
Unread 14-09-2004, 07:04
President, VEX Robotics, Inc.
Gerald,
Here are a few suggestions:
1. Use the CIM motor (if it is in the kit), not the drill if you want to simplify your system. Many teams have successfully used the drill motor, but if you want a robust and simple drive use the CIM motors.
2. Do not shift. That can be your next step after you get comfortable with drive train design.
3. If you are designing 4WD or are using chains at all, then use 3/8" (also called #35) pitch chain because it is much more forgiving.
4. Experiment with different wheel materials. Many teams have been successful using the skyway wheels and putting extra tread material on them.
5. Look in the white papers section about the different designs and the different analysis techniques used to aid drive train design.
6. Ask a lot of questions on this forum.
-Paul
Unread 14-09-2004, 07:38
Andy Brockway Andy Brockway is online now
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Gerald,
We have found that with the drill or CIM motor you will have a drive system that runs reliably if the following conditions are met:
1. Use chains or spur gears, do not use the right angle gearbox.
2. Final rpm of the wheel, calculated from the free speed of the motor, should be approximately 200-250 rpm for an 8" wheel. Example-bosch motor and gearbox had an output speed of 450 rpm in low, a 2:1 sprocket/chain reduction to the 8" wheel equals 225 rpm at the wheel. If you use a different size wheel than change the sprocket ratio (3:1 for 12" wheel).
We have used the skyway wheels every year. Wheelchair, 3x8 and 2x8 foam and the pneumatic. Your goal for this coming year should be simple and reliable.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 14-09-2004, 08:50
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Im going to chime in also...
Given im relativly new at designing geartrains, Ive been around FIRST for a while and i know what works and what doesnt.
SIMPLICITY
Being (as i assume) a sophmore team, you kind of get the idea that your rookie year you would see what works, what doesnt work, and what other people have done.
I like the Atwood motors. They are easy to mount, and you can mount it anywhere.
Go for a simple reduction. Estimate the FPS you want to acheive by figuring out what wheel diameter you want to use. then lets say you want a 6" wheel with a desired output FPS of around 8
*USE JVN'S SPREADSHEET*
Input your drill using a 14tooth 20dp.
From the 14tooth go into a 64tooth 20dp.
*thats just gearing*
then on your box's output shaft use a 10tooth #35 sprocket
to a 28tooth #35 sprocket on your wheels
THis would give you 9FPS
PM me if you would like a copy of this spreadsheet i used.
I would recommend using the skyway wheels that come in the kit. the 6" ones. and cut grooves in them for added traction.
and please if you have ANY questions, feel free to ask anyone of us who post here regularly for help...i have been helped my Andy and John. They aer very helpful for questions.
GOOD LUCK!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 14-09-2004, 09:08
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
1. Use the CIMS
2. If 4 wheel drive have a caster mechanism to pick the 2 front or 2 back wheels up! It is very hard to turn in 4WD.
3.Place your tranny at the back of your robot. Take the output of the trannies to each back wheel. Then take a chain from the back wheel to the front wheel.
Last year we used #35 chain on the output to the back wheels. We then used #25 to connect the front and back wheels. We never had a problem with the #25 chain. If the #25 chain does break then you probably just saved something in your tranny from breaking; you will still even be able to drive around (three wheel drive) YAY!
I have more up my sleeve just can't think of them off hand.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 14-09-2004, 19:27
CAD Mentor
AKA: Gerald Bailes
Exclamation Re: Help with drive train
Wow, thanks with all the help guys! Here is what we did last year:
First, we used 4 drill motors with the transmissions to obtain a 4 wheel drive. We figured out that it didn't work very well at all, we couldn't turn worth crap and the trannys kept slipping. We also used 2 of the big 12" pneumatic tires and the 2 other wheelchair tires.
Next idea, we replaced the 2 wheelchair tires with 2 more 12" pneumatic tires. We did this to try to get up the step. Another problem, we did not have the power or traction to get up the step, scratch that idea.
Final idea, completely take off the front two systems and replace them with good ol' casters. No getting up the step but it helped us maneuver a little better. Sigh...another problem, we were not used to the whipping action of the bot so it eventually threw out our battery. Very embarrassing.
So, as you all can see, we had a wonderful time learning what works and what doesn't, but we still haven't found what works. Thanks to all of your help, we should prevail over the dilemma of the drive train.
Thanks a bunch and I hope to see all you guys in upcoming events and meet you guys.
Unread 15-09-2004, 00:37
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
To give you an idea of what works. Here's a simple 2 speed transmision. You'll need an additional reduction after the output shaft but it'll give yah enough power to turn in 4wd if that's what yah want.
http://technokats.org/documents/shiftonfly.pdf
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 15-09-2004, 00:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I would not call the Technokats transmission simple (and this is coming from someone who was responsible for all the machining for an almost identical copy)
The principle is simples, however, it is most definitely not simple to make some of the parts without a CNC mill, something my team lacked. it can be done by hand, however it is VERY time consuming.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 15-09-2004, 07:55
Engineer
It is good this did not work. Per the rules you would have only been allowed to keep two of those motors on the robot at the competition, this would have left you with a robot with serious drive problems and no time to fix it.
The rules only allow the type and number of motors supplied in the kit. Two drill motors means only two on the robot. Of course more can be bought as spares in case you fry. This is a common mistake by rookie, and sometimes veteran, teams. I remember a couple of years ago the kit list said we had a van door motor when we did not. FIRST updated the list but one team showed up at an event with the van door motor on their robot .
Andy Brockway
Unread 15-09-2004, 07:59
Gerald,
You went through the motions so many rookie teams have gone through. (and a lot of veteran teams)
1. Four wheel drive (tank drive) works great when going in one direction but you can't turn on carpet so you need a method of lifting the two wheels off the carpet or turning them as part of the steering.
2. Using large tires can accomplish certain goals but the circumference of the tire needs to be considered in the final gear ratio choice. It is difficult to get good control with large tires at normal speeds in the torque range of the motors supplied. There are so many trade-offs.
3. Casters work OK but give the same problem that grocery carts have and that is the need for incredible steering torques to be stable and maneuverable. They also give a varying response when changing direction due to a fixed turning diameter of the caster.
4. Battery must be secure and protected within the robot. No battery=no play.
All in all you have learned a lot your first season out. Keep using the people here on CD as a resource, they are the best.
Unread 15-09-2004, 08:08
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
Our team usually bends a small little sheet metal slot to put the battery in and puts a few strips of velcro on. But every year, it comes down to one thing that keeps the battery in there... the good ol' zip ties. Go get a bunch of the longer ones (or however long/short you'd need it) and tie the two battery connectors together and then again to some sturdy point on your bot (this year we did it to our air tanks) It never fell off after that... but then you get the times when you got like... 10 seconds to get the thing on the field and you're all scrambling, "WHERE'S THE ZIP TIES!!!!1 OGMGOMG"
Regarding the drive train, if you're lucky, might get a game like 2002 where having casters would work alright. My team in '02 had the drive wheels at the back and casters at the front; no problem turning with that.
Joules per second! Watt? Joules per second! Watt? Jouls per second! Watt?
Unread 15-09-2004, 16:29
CAD Mentor
AKA: Gerald Bailes
All the help is really great guys! My mistake, we used 2 drill motors. sorry for the mix up.
Unread 16-09-2004, 15:38
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
We used ball casters - available from Mcmaster carr in 03 and did not have the swerve problem as bad -
This is considering we are now a 6 year rookie team.
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
Unread 16-09-2004, 16:59
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
just to chime in, watch your wheel base, we had the problem of getting too much traction and had too much distance between axles therefore we could not turn.
hope this helps
good luck, the more you play with it the more solid it will be
Marcus
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
White Paper Discuss: Drive Train Basics CD47-Bot Extra Discussion 6 06-09-2012 11:42
Coolest Drive Train team222badbrad General Forum 15 01-09-2004 19:06
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
