Go to Post Nominate your mentor for WFA, it's the best way to say 'Thank You'. - Brandon Martus [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 08-09-2004, 14:05
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Bosch Motors
Originally Posted by Matt Reiland
Also the size of the motors in the KOP should have no difference between a rookie team and a veteran. A veteran team with resources will use whatever is in the kit to the max abilities.
Familiarity with the motors is what I meant. All new motors means we all have to figure out how to use them and their capabilities from scratch. I am for this because I want FIRST to throw us a curve ball this year.
Unread 08-09-2004, 14:23
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Bosch Motors
It looks like the reason FIRST is dropping the Bosch drills is that Bosch no longer makes a 1/2" 12V drill. I'm hoping they go with something like the DeWalt DC980KA motor and transmission. Three speeds would be nice, as would a 4:1 ratio between high and low gears.
Zan Hecht
Unread 13-09-2004, 21:04
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: Bosch Motors
I for one would like to see the jump to a 24 volt electrical system...MORE POWER! and yea, with less current, the wire size can decrease, and we can have more weight for the bigger motors! or other functional devices.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 13-09-2004, 22:00
Billfred's Avatar
Billfred Billfred is offline
Re: Bosch Motors
This is true...however, consider this:
Which is lighter, an extra battery (or the difference between the current batteries and a 24v version) or the extra wire required to handle the current current?
Unread 14-09-2004, 07:47
coreyjon's Avatar
Flight Engineer
Re: Bosch Motors
ok ok, you got me. we probably wont be seeing any savings in weight going to a 24 volt system. but think about the extra power, and what we could do with it!
Unread 11-10-2004, 17:26
Re: Bosch Motors
Originally Posted by Greg Needel
btw i heard there will be NO kit of parts this year for veteran teams
then technically, you dont need to stick to what motors are in the KOP.
Electric car motor, here i come.
Unread 11-10-2004, 17:30
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Bosch Motors
The guy @ Bosch said that FIRST is getting some third party company to "design" them a motor....i don't know how credible it is, but it is worth mentioning
Unread 11-10-2004, 17:57
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Bosch Motors
Source? I'm really, really, interested where you heard that. If it were true it would be VERY interesting
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 11-10-2004, 18:44
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Bosch Motors
Though I can't comment on the credibility of that source, that's more or less what seems to have happened with the CIM motor. In 2002 we had a version of that motor manufactured for Atwood. Subsequently, CIM supplied a FIRST-specific version using the same enclosure, but with a different shaft (and possibly slightly different internals).
Unread 11-10-2004, 19:53
BSEE, MSEE, JD
AKA: employed
Re: Bosch Motors
ahh....interesting
hopefully they will make the pinion standard instead of metric.....or what the heck just give us a shaft with a keyway on it.
Unread 11-10-2004, 21:03
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Bosch Motors
and I wonder why this stuff is in the rumor mill...
Unread 11-10-2004, 23:01
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Bosch Motors
Errr... It would be a bit of a waste of money to have a company design a motor... I mean the CIM output isn't that much to do, especially if you're doing bulk. But design? That takes a bit of money to do. I don't know about you, but I would like it if the kit of parts would cost less this year, seeing as one of my teams is almost dead broke. Registration fees are hard enough to pay.
However if it's just modifying a known motor to be FIRST specific, thats not too bad. How about a keyed shaft?
Unread 12-10-2004, 23:46
occra 23.
AKA: ryo
None #1481
Re: Bosch Motors
ehh.. id go with an electric airplane motor. like the so called solar powered HELIOS.
Unread 07-01-2005, 14:53
Revolverx7's Avatar
Revolverx7 Revolverx7 is offline
Ninja
AKA: Sanders
Team Role: Driver
Revolverx7 is on a distinguished road
Send a message via AIM to Revolverx7
Re: Bosch Motors
I don't know, I work for Sears, I will ask one of my managers.
Unread 07-01-2005, 15:02
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Bosch Motors
You don't need to ask about drills... we won't have them this year.
FIRST (accidentally?) didn't encrypt the part of the manual that lists what motors FIRST will have available at events, and drills of any kind were'nt in there
2001-2004: Team 100
2006-Present: Team 254
Trade - have Bosch gearboxes, need motors Andy Baker Motors 0 24-01-2003 08:32
Bosch motors archiver 2001 1 23-06-2002 23:08
