Go to Post - Just because you can buy 50 giant pixie stix with your roommates Sam's club membership does not mean you should eat them all at once. - Not2B [more]
Unread 15-09-2004, 17:16
pi_guy578 pi_guy578 is offline
Programmer/Electrician
AKA: Jake
FRC #0578 (Blue Lightning)
pi_guy578 has a spectacular aura aboutpi_guy578 has a spectacular aura about
Send a message via AIM to pi_guy578
Re: Saving a variable in between runs.
Originally Posted by 527Paranoia
Yes this is all well and good if you variable is not going to change in mid run, then use that same value again in the next rounds. This EEPROM is used for people who need to dynamically change variables and use them at a different time.
I'm using it to store p1_x values that a gyro calculated to make it go strait. Then next time I hit forward on the joystick it would start off with the calculated p1_x value instead of default 127. This (hopefully) will eliminate any beggining turning while the gyro is building up error.
As far as I can tell it would make no difference then b/c the program memory is also an EEPROM (or similar, can't remember) except the storing is auto handled instead of doing it manually using the user EEPROM where you can make errors.
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
Interrupt Handlers and Variable Scope kaszeta Programming 2 14-02-2004 18:30
variable? manodrum Programming 11 01-04-2003 17:20
Dashboard programs and the char variable Ian W. Programming 13 26-06-2002 02:07
what teams have a variable transmissions? Greg Perkins Technical Discussion 4 06-03-2002 06:10
