Go to Post Although I'm 2-0 against 217 when Paul coaches, I'm 0-2 against them when he doesn't....hmmm.... :rolleyes: - Lil' Lavery [more]
Unread 16-09-2004, 20:46
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 1305 Frame design with trannies
Unread 16-09-2004, 20:47
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: pic: 1305 Frame design with trannies
ah, baker transmitions with a box tube frame. OHH! and whats this? sinking the drill motor into the box tube. Somone stole my idea, Or mabye its a good idea and you came up with it too?
Unread 16-09-2004, 20:54
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
They are a completely new trannsmission That I designed. Although I was definetly heavily influenced by Baker's design. It is designed to have Brecoflex tracks in the gap between the The 2x4s and the outsice plates, So the driveshaft out of the Trannies is designed to turn the back drive pulley for the tracks. The trannies are 2 speed with approxiamte speeds (70% of free speed) at 3.4 ft/sec and 9.5 ft/sec. Kinda slow compared to other designs but This is designed like a bulldozer.
Unread 16-09-2004, 20:58
Hunter's Avatar
Wood is Good
AKA: Todd Willick
I know the drill motors are cancelled but this was designed before then, and besides, it would take only a very small effort to convert the trannsmissions to use any other similar motor. And I'm hoping we get the Dewalt drill motors, they would swap in easily.
Unread 16-09-2004, 21:02
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
How much do the transmissions weight... just a suggestion... make sure the robot weight is balanced... our 2003 robot was back heavy since the transmission was in the back like your design... but i think we only flipped once... the overall design looks great... the frame looks strong... you might have to change your transmission depending on what motors they give us this coming season... good luck...
p.s. Never mind my changing tranny comment... i think you just click submit just a second before i did...
Unread 16-09-2004, 21:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What is the thickness on the outer plates and on the wall of the tube. I'm guessing it is 1/8" If so, the plate needs standoffs between it and the tube, and the tube needs some serious HOLES. Also, other than mounting your trannies? is there any reason that tube is so big, I mean, for the rest of the way down the frame?
Unread 16-09-2004, 21:08
Hunter's Avatar
Wood is Good
AKA: Todd Willick
The trannies wheigh 9.3 pounds With everything on them you see there (according to inventor anyway). We still have to build them, we are waiting for gears. So they might not even work, but thats why we are building them now.
Unread 16-09-2004, 21:15
Hunter's Avatar
Wood is Good
AKA: Todd Willick
Like I said before it designed to fill the bulldozer role on the field. Those are the 2x4x1/8 tubes like we got in the kit last year, and the outside plates are 3/16. there will be standoffs as part of the track system, but I didn't add them in yet. both the 2x4's and the outside plates will likely end up full of holes in the final robot (If it turns out that we can even use this design next year), then we will just Epoxy a piece of 1/16 lexan over the holes on the outside plates to keep stuff from getting caught in them (bad experience in atlanta with stuff catching in holes).
If we end up building this we will deside where mechanisms need to be mounted before drilling any lightening holes to make it easy to mount stuff.
By the way the bottom plate is only 1/16, just to help keep the frame square and mount stuff like the battery and electronics to.
Unread 16-09-2004, 21:29
3/16" looks like a good choice for those plates. I know your not anywhere near this point, but if you could get EVERYTHING laid out in Inventor (like early in the build) then you could get some really (big) nicely lasercut or waterjetted holes in those tubes and plates. As for the bottom pan, you could probably go with a little bit thinner even and then roll some beads in it (or get it embossed) and it will really stiffen it up and look cool too.
Unread 16-09-2004, 21:33
Justin Boudreau's Avatar
Justin Boudreau Justin Boudreau is offline
FRC #1305 (NNSRI)
Justin Boudreau is a glorious beacon of lightJustin Boudreau is a glorious beacon of lightJustin Boudreau is a glorious beacon of lightJustin Boudreau is a glorious beacon of lightJustin Boudreau is a glorious beacon of light
Haha, unfortunatly laser or watercutting isn't an option for us. It would be nice, but we'll be lucky to afford the gears.
Unread 17-09-2004, 01:53
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
It never hurts to ask. The worst they can say is no, or tell you a price. Alot of businesses will openly donate services to teams, but they will never know you want their help unless you ask.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 17-09-2004, 16:34
K.Shaw's Avatar
K.Shaw K.Shaw is offline
The Zoomin' Human
AKA: Shaw 1, kevshaw, little shaw
FRC #0237 (Sie-H²O-Bots (See-Ho-Bots), FLL #3954 (Swift Eagles))
K.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant futureK.Shaw has a brilliant future
Send a message via ICQ to K.Shaw Send a message via AIM to K.Shaw Send a message via MSN to K.Shaw Send a message via Yahoo to K.Shaw
all i have to say is if those drill motors die or crap out its gunna b a pain in the $@#$@#$@# to changed them.....cool design though
2005 Bash @ the Beach Winners -Thanks Team 1511 and Team 181
2005 NJ Regional Finalist -Thanks again to 56 and 303
2005 Radioshack Innovative Control Award-NJ
2005 FLR Semi-Finalists
2005 Radioshack Innovative Control Award-FLR
2004 Archimedes Divisional Semifinalists
2004 NJ Regional Winners. -Thanks Team 56 and Team 303!
2004 NJ G.M. Industrial Design Award Winner
2004 UTC Motorola Quality Award Winner
Unread 17-09-2004, 17:34
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
"flock their sheep"
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
looks pretty awesome guys.. by bulldozer.. i wonder how what the torque stats are . we can keep up a canadian way of being able to push everyone around, just not in real life .
i hear you about the waterjetting *sigh*
Woburn Robotics, Class of 2005.
Unread 17-09-2004, 18:11
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Just put the battery in the front.
-Paul
Unread 21-09-2004, 18:34
Hunter's Avatar
Wood is Good
AKA: Todd Willick
The Drill motors actually come out quite easy, just a couple of set screws that Protrude into the holes in them and some gental taps and they should come right out all the way through the 2x4.
As for tourque, it has approximatley 31.5 theortical ft/lbs of tourque at 40 A per side in low gear, giving it pushing theoretical pushing force of 378 pounds at 40 A not taking any friction etc. into account. That is about 1100 pounds of push at stall in low gear, Which is impossible to reach since the battery can't provide that kind of current. Combine that with VERY grippy tracks and we should be somewhat of a bulldsozer out there, with good intentions of course.
pic: My vote for the best design from the team spirit "drawn" in the stands. CD47-Bot Extra Discussion 4 07-09-2004 00:19
pic: Team 303 Winner of the GM Industrial Design Award CD47-Bot Extra Discussion 9 20-04-2004 19:57
pic: team 1305 - The Mammoth Ayu Robot Showcase 2 04-03-2004 23:33
pic: 1083's final design unleashed!!!! The MIKEBOT 2000 CD47-Bot Robot Showcase 8 20-02-2004 23:41
pic: Team 710 Frame CD47-Bot Extra Discussion 4 16-02-2004 19:01
