Go to Post I am a big fan of community building exercises. And harassing my friends. - Amanda Morrison [more]
  #38   Spotlight this post!
Unread 17-09-2004, 22:32
RBrandy RBrandy is offline
AKA: Ryan
#0093 (NEW Apple Corps)
RBrandy is a jewel in the roughRBrandy is a jewel in the roughRBrandy is a jewel in the rough
Send a message via AIM to RBrandy
Re: Best frame building material
Originally Posted by Rickertsen2
Vould you please elaborate on this a little bit? first off is does FRP come shaped like a panel? Or rods? tubes? what? I'm a little confused. It sounds to me liek you are saying it is a panel and you put in in the T-slot of unistrut?
First, let me answer this. We got square tubes. I believe it comes in a whole array of shapes and sizes. We took the unistrut, machined it down to a size that would nest tightly, but not too tightly, in the FRP. Then, we taped the hole, and screwed it in at a 90 degree angle to the instruct.
This is not frame related in the aspect you are asking about. Team 93, in addition to using the fiber glass (FRP), we also used a large 1/4 in. plate for mounting things, instead of using more pieces of 80/20. We used it to mount gear boxes, our battery, our electronics box, our programming, air compressor, etc. To make this plate strong we had one of our engineers brothers laser cut, then bend out 'ribs', if you will, to make sure it would not flex in any critical part. This part helped the robot meet the weight requirement and still stay robust.
I'm sure myself or Sean Schuff could conjure up some pictures of this plate so you can understand what I'm rambling about.
Team 93 Alumini
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Rendering Tips Tyler Olds 3D Animation and Competition 27 16-10-2003 01:32
Building material archiver 2000 1 24-06-2002 00:10
frame material survey punarhero Technical Discussion 12 21-02-2002 06:47
